Pro Drive prop removal https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=59890 |
Author: | SmokyOkie [ Thu Feb 05, 2015 5:50 pm ] |
Post subject: | Pro Drive prop removal |
I need to replace the lower unit seal nut on my Pro Drive. In reading the owners manual, it says to use a prop wrench. This looks like a piece of 2 or 3" aluminum flat strap with a hole in one end. I don't have one of these. Is there a quick easy substitute for the wrench? Could I not just buy a piece of aluminum and drill a hole in it? |
Author: | butternut [ Thu Feb 05, 2015 6:27 pm ] |
Post subject: | Re: Pro Drive prop removal |
yes or a flat piece of metal will work. |
Author: | SETx Longtail [ Thu Feb 05, 2015 6:30 pm ] |
Aluminum will bend. Get a piece of steel flat bar. |
Author: | 270Handiman [ Thu Feb 05, 2015 6:31 pm ] |
Author: | SmokyOkie [ Thu Feb 05, 2015 8:02 pm ] |
I a also trying to figure out, you remove the prop nut, why do you need a wrench to remove the prop. It isn't threaded onto the prop shaft is it? |
Author: | JLACOUR [ Thu Feb 05, 2015 8:10 pm ] |
Yes the prop is threaded on the shaft. You just changing props? |
Author: | Russ [ Thu Feb 05, 2015 8:43 pm ] |
No. He's replacing the lower unit seal nut. |
Author: | JLACOUR [ Thu Feb 05, 2015 9:18 pm ] |
Wow missed that Russ. Thanks. I wanted to mention that the prop nut seal has left handed threads! |
Author: | SmokyOkie [ Thu Feb 05, 2015 10:46 pm ] |
Author: | ha2 [ Fri Feb 06, 2015 1:10 am ] |
no bushing is not threaded. it's tapered and should most of the time come off with the prop then just take a pliers and squeeze it a little and it comes out. make sure to put marine grade anti sieze on everything prop shaft and bushing when you put it back together. |
Author: | SmokyOkie [ Fri Feb 06, 2015 7:58 am ] |
Where do you get marine grade anti seize? |
Author: | OwenDickeson [ Fri Feb 06, 2015 9:19 am ] |
2x4 with a hole drilled in it works fine for me. |
Author: | Terraboat [ Fri Feb 06, 2015 10:10 am ] |
A week BEFORE prop removal, spray some quality penetrant oil at front and back of prop. It will save a lot of cussing. I always used a 2x4 with hole drilled in it. Most auto stores have marine grade anti-seize . Or just eBay it a week ahead of time. Helps to remove prop I ce every year, needed or not. Gen. 3 lower unit is much better since they dropped thread prop BS. |
Author: | BadBowtie [ Fri Feb 20, 2015 11:31 am ] |
This worked for me. Wouldn't budge been on there for 3 seasons. Had this made, she came right off. Sent from my iPhone using Tapatalk |
