It is currently Sun Jun 29, 2025 8:08 am
Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 GTR Reverse Help
Post GTR Reverse Help
I just got my new reverse housing in from gator tail.. I was wondering if any one could steer me in the right direction to changing the housing. I have the entire new unit with the main bolt. Any advice on how to remove the old reverse and put on the new unit?
18x54 GTB 35GTR "the hairy merganser II"
"Sometimes you just gotta hang your pistols up and let your hair down"
Wed Jun 12, 2013 1:21 pm
Post Re: GTR Reverse Help
Sent from my DROID RAZR using Tapatalk 2
Wed Jun 12, 2013 1:35 pm
Take the reverse cover off, then remove the brake caliper, then there is 2 screws in the reverse housing to drain the oil out of it. Then remove the center bolt with an impact, then carefully remove the magnatized shaft off of the crank shaft (there is a cotter key inside of it becareful not to drop in in the belt housing). Then remove the brake disc with the planetary gears attached. There will be some black allen screws holding the reverse housing to the gear, undo those allen screw and remove the housing.
Wed Jun 12, 2013 1:36 pm
It's not hard but I would have to see what parts you have to help you
17x48 extreme stage 2 GTR
Wed Jun 12, 2013 1:41 pm
Just as Jamie said easy 15 minute job. Sorry while I was typing Jamie posted
Wed Jun 12, 2013 1:42 pm
Thanks fellas.. this center bolt just spins any suggestions to getting it off? Never done this job just don't wanna over look something stupid lol
Wed Jun 12, 2013 2:15 pm
I put a hammer to my wrench
Wed Jun 12, 2013 2:17 pm
Sneak up on it then quick pops lol
Bout to pounce lol
Wed Jun 12, 2013 2:26 pm
Down to this.. trying to understand what Jamie said is next...
Wed Jun 12, 2013 2:31 pm
grab that big piece there in the center and pull it out then you will see the allen screws ;)
Make sure to drain the fluid and watch for the small key in shaft!
Wed Jun 12, 2013 2:34 pm
put some rags on housing so you don't drop shit in it!
Wed Jun 12, 2013 2:35 pm
Take the caliper loose!You don't need to remove the rotor from trans.
Wed Jun 12, 2013 2:36 pm
1754 Extreme GTB / GTR35
Wed Jun 12, 2013 2:57 pm
It worked lol
Wed Jun 12, 2013 3:00 pm
I wanted you to leve the disc on so you had something to grab to pull it out. lol
Wed Jun 12, 2013 3:02 pm
Lol got that figured out everything is off now gotta find my 4.5 Allen key.. shoot me lol
Wed Jun 12, 2013 3:19 pm
Thanks fo that help errbody
Wed Jun 12, 2013 3:29 pm
Just make sure you leave one of those oils drain screws out when you slide the reverse back on
Wed Jun 12, 2013 3:32 pm
One of the inner Allen bolts stripped... one of those days.. ideas?
Wed Jun 12, 2013 3:58 pm
Slow down bro. O your fucked lol
Wed Jun 12, 2013 4:01 pm
CAREFULLY drill out the head until it's just the stud left, then use a vise grip to remove the stud after taking off the outer gear
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Try using a torx bit. I've had Allen heads strip and that usually does it
35 GTR chasin a BBC 1848
Wed Jun 12, 2013 4:20 pm
That's what i was thinking but wanted to get the okay on that haha.. It stripped with a screwdriver.. I guess im alot stronger than i thought or it was a weak screw. Last one too.. I'm gonna take this as a sign to quit for today and start again tomorrow. Thanks again fellas
Wed Jun 12, 2013 4:21 pm
Not sure if it will work,you can probably use an easy out .
1854 GTB Extreme 35GTR
Wed Jun 12, 2013 5:55 pm
Torx bit or tap an Allen wrench one size bigger than the stripped one into the head.
HOTSAUCE170 wrote:
Wed Jun 12, 2013 6:54 pm
take it to calen
- Mark Twain
Wed Jun 12, 2013 6:55 pm
Wed Jun 12, 2013 7:12 pm
New I just called Hoyt and he sent me the entire reverse housing so I don't have to fool with the seal. Got some easy out bits dirty gonna give them a shot when I get back to Columbia. In better news 8 new 27 watt LEDs showed up and already got that prewired ready to mount!
Fri Jun 14, 2013 11:29 am
Fri Jun 14, 2013 12:48 pm
You can alway knock a flat head screw driver in to it and get it out
Fri Jun 14, 2013 3:31 pm
Jeezus, what a production.
Fri Jun 14, 2013 4:28 pm
Hows ur airboat?
Fri Jun 14, 2013 4:36 pm
Fri Jun 14, 2013 4:56 pm
Fri Jun 14, 2013 5:04 pm
Fri Jun 14, 2013 5:23 pm
Fri Jun 14, 2013 6:40 pm
Fri Jun 14, 2013 7:45 pm
Torx bit got it out.. got a little gap in the main bolt putting it all back together... any reason for this? Gt guys are at lunch
Fri Jun 21, 2013 11:16 am
Fri Jun 21, 2013 11:17 am
Users browsing this forum: Google [Bot] and 237 guests
