It is currently Sun Jun 29, 2025 6:12 am
[ 7 posts ] |
jakefromflorida
 older 27hp prodrive
Just bought my first surface drive and trying to become acquainted with it and educated on all the moving parts...
Is there a owner manual or a exploded view of the drive shaft assembly? I'm assuming the motor block is nothing more then a mower engine, so I could use that parts list. What motors does pro drive use?
Just looking for all and any information on it so I can learn more about it. I also need to replace the Skeg eventually, it has a nice 2 inch crack at the very bottom...
Other then that does anyone have a list of suggested maintenance chores to do at specific hours? It only has roughly over 100 and runs solid, and oil changed regularly.
Thanks in advance.
Mon Feb 23, 2015 12:37 pm |
jakefromflorida
 Re: older 27hp prodrive
It's a 2003, and I've just learned I may need to replace the top seal. Draining it now and about to flush it. Once refilled I'll run it once and check it again. If still leaking where can I get the top seal at? If not too bad to replace, I might do the bottom as well.
Thanks in advance guys
Mon Feb 23, 2015 3:57 pm |
jakefromflorida
Well, drained and flushed the lower unit. Took it for a spin and had this sitting on top. I'm assuming I definitely need to replace the top seal?
Mon Feb 23, 2015 5:43 pm |
OwenDickeson
The prop seal needs to be replaced most likely. Call Pro-Drive tomorrow and ask for Peck.
Mon Feb 23, 2015 6:02 pm |
jakefromflorida
Been talking with peck, he suggested just to flush/drain then run it again. After tonight I agree... Probably need that seal.
Mon Feb 23, 2015 6:20 pm |
jakefromflorida
Just ordered the bottom seal from peck this afternoon. Going to tear it down next Monday or Tuesday and assess what else I need... Possibly top seal as well and I want to get a better look at the clutch assembly. Does anyone have a video or direct link when replacing these seals?
Thanks
Tue Feb 24, 2015 1:02 pm |
jakefromflorida
I thought I remember reading something somewhere about using marine grade grease in correlation with the seals?!
Surely I read this incorrectly? I plan on doing my lower seal tomorrow and would like to know...
Just pull the prop, replace old seal, and put new nut on right?
Thanks
Fri Feb 27, 2015 7:35 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 247 guests |
