Advantages of foot on trailer jack??
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=60832
Author:  MNGunner [ Wed Mar 18, 2015 6:52 pm ]
Post subject:  Advantages of foot on trailer jack??
I just bought a larger utility trailer and it came with a trailer jack that has a flat foot. All my other trailers have had a trailer jack with a wheel. I'm toying with the idea of cutting it off and replacing it with a caster wheel like this one:
http://www.summitracing.com/parts/REH-74326?seid=srese2
Is there any advantage to having a fixed foot over a wheel?? I'm sure they have a higher capacity rating (this one is rated to 2,000lbs), but that far exceeds my max tongue weight by a long shot.
Author:  SETx Longtail [ Wed Mar 18, 2015 7:34 pm ]
Post subject:  Re: Advantages of foot on trailer jack??
You could get a caster with a 4 bolt flange for a mount. That way, all your have to do is drill some holes and bolt it on, if you wanted to remove it, unbolt it. Simple.
Author:  FRANKtheTAU [ Wed Mar 18, 2015 7:41 pm ]
^^^^^ x2
Author:  flint87 [ Wed Mar 18, 2015 7:46 pm ]
The foot is bc a heavy trailer will sink that skinny little wheel into soft ground, especially when loaded.
Author:  dguidry [ Wed Mar 18, 2015 7:48 pm ]
If you repace it with a roller it will take longer for you to realize you have not lifted it when you take off.
Author:  msm8281 [ Wed Mar 18, 2015 7:50 pm ]
The flat foot slides pretty easy if it's not loaded too heavy on the tongue. Try it before you modify it.
Author:  MNGunner [ Wed Mar 18, 2015 7:54 pm ]
Author:  MNGunner [ Wed Mar 18, 2015 7:55 pm ]
Author:  flint87 [ Wed Mar 18, 2015 8:13 pm ]
