How much HP do I need?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=61578
Author:  shawnw [ Sat May 02, 2015 9:43 am ]
Post subject:  How much HP do I need?
I have a Tracker 2072 with a hardside aluminum blind. I currently have a 75hp Honda but am thinking about going to a surface drive. Will I be happy with a 35hp? I don't think I want to afford twins. What do you guys run on your big jons and how happy are you with them?
Author:  Russ [ Sat May 02, 2015 10:06 am ]
Post subject:  Re: How much HP do I need?
You won't be content with a stock 35 or a stock 37 efi based on past opinions here.
Depends on your expectations though.
You won't need all the mods available, but a cam, a carb, and headwork should make it more than capable with that boat, I would think. If you go efi, then headwork, cam and exhaust.
Author:  Russ [ Sat May 02, 2015 10:07 am ]
The stock efi is only 500 more than stock 35 (carbed model)
Author:  LB200 [ Sat May 02, 2015 10:36 am ]
As much as you can afford. Seems like no matter how much anyone has they want more. Of course, the cost to adding a couple miles per hour can add up quickly and sometimes cuts into the life expectancy of the motor.
Author:  mikecatt13 [ Sat May 02, 2015 11:45 am ]
Author:  Russ [ Sat May 02, 2015 12:56 pm ]
Correct. But with efi, who needs more mods ?? :D:D
Author:  banded-mallard [ Tue May 05, 2015 4:40 am ]
