It is currently Sat Jun 28, 2025 12:12 pm
Reply to topic  [ 7 posts ]
 Prodrive Clutch
Post Prodrive Clutch
Did anyone have problems with their Prodrive clutch. The clutch does not slip but it seems it is grinding in that area and causing the engine to die in gear. not sure if its a simple fix or not.
Tue Jan 04, 2011 7:35 pm
Post Re: Prodrive Clutch
how old is your motor? how much wear and tear do you put on your motor? its probably just getting older and its about to go out on you.
Where you from with that Cheramie name??
Wed Jan 05, 2011 9:37 pm
Sun Jan 09, 2011 3:25 pm
Let me know if you need a clutch. I am located in Morgan City. I can Pick you one up tomorrow when I travel to PD.
Sun Jan 09, 2011 3:53 pm
just sent my lower unit to pro drive to be rebuilt and I get it back and go ride for about 45 minutes and it started smoking all around the clutch. didn't hear no noise but they got a strong smell around the clutch. I killed it for about 20 minutes cranked it back up and idled for about 10 minutes and it don't smoke no more.
Fri May 01, 2015 10:34 pm
just sent my lower unit to pro drive to be rebuilt and I get it back and go ride for about 45 minutes and it started smoking all around the clutch. didn't hear no noise but they got a strong smell around the clutch. I killed it for about 20 minutes cranked it back up and idled for about 10 minutes and it don't smoke no more. need some advice please help
Fri May 01, 2015 10:36 pm
Sounds like you got something in a bind when you reassembled it.
Mon May 04, 2015 6:07 pm
Users browsing this forum: No registered users and 368 guests
