Crack in skeg!! https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=6250 |
Author: | marshduck [ Sun Nov 29, 2009 1:27 pm ] |
Post subject: | Crack in skeg!! |
Cleaning boat the up after hunting this weekend and noticed a crack in the skeg of my two month old Prodrive. It is about 2.5 in. long. Ran in shallow water with sand bottom at the Wax, don't remember hitting anything. Has anyone else had this problem? |
Author: | dylndaw [ Sun Nov 29, 2009 1:39 pm ] |
Post subject: | Re: Crack in skeg!! |
thats not anything to worry about. just keep an eye on it because it is your rudder. the hole is there to keep it from cracking but does not work very well as you can see. this is normaly caused from hitting a stump or submerged tree. |
Author: | forever draggin [ Sun Nov 29, 2009 1:52 pm ] |
call pro drive, they may weld it up for u, or replace it. |
Author: | bayouboy [ Sun Nov 29, 2009 6:43 pm ] |
I want to say that hole is one of many and it is there for the installation of the rock guard. Mine stock skeg cracked the same way. I just drill a 1/4" hole at the end of the crack and kept on truckin. The new hole will stop it from going any farther. |
Author: | allenoutdoors [ Sun Nov 29, 2009 6:47 pm ] |
get it welded up and run the crap out of it...now it has character! ![]() |
Author: | dylndaw [ Sun Nov 29, 2009 7:09 pm ] |
good call preston.the hole does have a purpose. |
Author: | bayouboy [ Sun Nov 29, 2009 8:06 pm ] |
Author: | dead animal [ Sun Nov 29, 2009 8:42 pm ] |
Author: | ff154 [ Mon Nov 30, 2009 2:32 pm ] |
I just went out and checked mine. It's cracked exactly like that. I guess I will be tending to that next chance I get. |
Author: | POKER1 [ Mon Nov 30, 2009 4:25 pm ] |
Just drill a hole at the end of the crack and that should stop it from going further. |
Author: | willett [ Tue Dec 01, 2009 10:29 am ] |
drill a hole grind some of the crack out on both sides weld it all up will definately stop it |
