Oil galley O-ring https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=63731 |
Author: | wing dam [ Thu Sep 17, 2015 8:59 am ] |
Post subject: | Oil galley O-ring |
Looking for a little help. Replacing the case gasket on a 23hp briggs, it is recommended to replace the o-ring on the oil pump. I have a new o-ring for the oil pump but not sure on taking the pump apart. I assume you need to remove the plastic gear that runs the pump and o-ring is behind the pump? How does the plastic gear come off? Let me know if I am going the wrong direction on this please. PS Do you guys use a former gasket/permatex or just replace the case gasket dry? Thanks |
Author: | txmudcutter [ Thu Sep 17, 2015 9:31 am ] |
Post subject: | Re: Oil galley O-ring |
i dont know about a o ring on the pump, but if your talking about the oil galley o rings they go on the case surface by where your filter goes. There should be two holes there where oil passes through, the o rings go there. |
Author: | wing dam [ Thu Sep 17, 2015 11:03 am ] |
Here is the diagram from the oil pump (part number 273) Just not sure how the o-ring is installed. |
Author: | Richard in LA [ Thu Sep 17, 2015 11:21 am ] |
The plastic gear doesn't come off, there should be 2 bolts on the back of the crankcase cover that hold the pump on. The other poster is right the o rings your looking for are the oil galley o rings that go where the oil passages are from the pump to the filter and back through the cover to the rear bearing. The only time the pump o ring needs to be replaced is if you remove the pump, as far as I know. |
Author: | DmaxHunter [ Thu Sep 17, 2015 11:57 am ] |
Don't see why that o ring would need to be replaced, unless disassembled. As for gasket, you need to buy another as it is a shim needed for the crank bearings. Permatex is used with gasket for best result |
Author: | wing dam [ Thu Sep 17, 2015 2:20 pm ] |
Thansk guys, will leave the o-ring alone. I have the gasket, will able some permatex with it. |
Author: | Richard in LA [ Thu Sep 17, 2015 4:43 pm ] |
The oil galley o rings do need to be changed each time the case is removed. They aren't really o rings, they are taller and compress when the case is installed . |
