| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| Throttle linkage on a PD36 https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=64009 |
| Author: | mudder [ Sun Oct 04, 2015 3:41 pm ] |
| Post subject: | Throttle linkage on a PD36 |
Is this why i have a little slop in throttle response? Are these two nuts/bolts suppose to be tight and flush? Sorry if this is a newbee question even tho i just turned 300 hrs in the motor. Thx Sent from my SM-G900R4 using Tapatalk |
| Author: | BlueShamu [ Mon Oct 05, 2015 7:14 am ] |
| Post subject: | Re: Throttle linkage on a PD36 |
Those two nuts are tight and flush. They are through a ball joint that is supposed to pivot. If you have bog or delay in throttle, it could be your governor needs adjustment or your carb could use some cleaning. Has it always done whatever it's doing or just started? Sent from my iPhone using Tapatalk |
| Author: | DrahthaaRunner [ Mon Oct 05, 2015 7:42 am ] |
That huge bend in your linkage might have something to do with it. But everything else looks good. Sent from my SM-G900P using Tapatalk |
| Author: | mudder [ Mon Oct 05, 2015 8:39 am ] |
| Author: | mudder [ Mon Oct 05, 2015 8:40 am ] |
| Author: | DrahthaaRunner [ Mon Oct 05, 2015 9:26 am ] |
It's just threaded rod, you can buy it from any farm and barn store and just cut to lengh. Sent from my SM-G900P using Tapatalk |
| Author: | mudder [ Mon Oct 05, 2015 3:02 pm ] |
actually just ordered the entire throttle linkage as PD noticed some other issues that got wacked out over time, but definitely more than I wanted to spend. |
| Author: | BlueShamu [ Mon Oct 05, 2015 7:25 pm ] |
Is it something they said they saw in those pictures? Most liberals seem to suffer from the same mental condition....it's called stupidity! |
| Author: | Woodiebuster [ Mon Oct 05, 2015 7:45 pm ] |
A mikuni is the best solution to the problem I believe |
| Author: | mudder [ Tue Oct 06, 2015 2:55 pm ] |
