minuki carb on pro drive add on https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=64596 |
Author: | old drake [ Mon Nov 16, 2015 9:34 am ] |
Post subject: | minuki carb on pro drive add on |
got parts for pro drive from performance brothers out of houston area a while back. they are no longer in business for a while. any one know what the discription of what carbs they used. from what i can see on web it is a HSR model with a side cold start pull out and throttle not straight off the top. not sure what size think 33m or 34mm. need some parts for it. any thoughts were to look for parts? thanks |
Author: | Russ [ Mon Nov 16, 2015 9:51 am ] |
Post subject: | Re: minuki carb on pro drive add on |
What size engine? And Google is your friend. As is the search function on here. |
Author: | old drake [ Tue Nov 17, 2015 7:12 am ] |
need to make correction it is a mikuni and it was the performance twins out of houston and it goes on a 36 hp pro drive thanks |
Author: | Russ [ Tue Nov 17, 2015 7:35 am ] |
It won't be a 33 or 34mm. The hsr comes in 42, 45, and 48mm. In all likelihood, it's the 42mm, but they all use the same jets and parts. |
Author: | brickgw [ Tue Nov 17, 2015 8:38 am ] |
Yep mikuni hsr42, you should be able to order just about anything you need for it from jetsrus.com |
Author: | old drake [ Tue Nov 17, 2015 9:58 am ] |
great I knew you guys would have it thanks |
Author: | cb5331 [ Tue Nov 17, 2015 10:28 am ] |
Author: | Russ [ Tue Nov 17, 2015 10:46 am ] |
For a stock motor, yes. It's on my father's motor now. It really hated mine. |
