It is currently Fri Jun 27, 2025 1:39 am
Reply to topic  [ 4 posts ]
 Gas tank / fuel question
Post Gas tank / fuel question
Guys just got my new mudmotor mounted. Hooking up the fuel lines tomorrow . Was hoping to place the gas tank towards the front of the boat. Will the fuel tank on a 23 godevil have enough pull to draw fuel from 13 ish feet away
Tue Nov 24, 2015 5:20 pm
Post Re: Gas tank / fuel question
Shouldn't be a problem. Just make sure all your connections are tight. You may want to make the connection at the tank direct (dont use a disconnect) to ensure you dont pull air thru the line. I have a yamaha disconnect and lose prime after the rig sets for a few days. My tank is up front on a 16 foot boat. My motor is old and has no problem drawing fuel to it. Forgot to open the vent once and almost collapsed the tank. You may want to install a water trap as well. Mount it at the back between the tank and motor. Preferably one with a see thru cup so you can tell if its collecting water. And dont forget a good primer bulb.
Tue Nov 24, 2015 7:17 pm
Thanks for the suggestion about connecting stuff directly ... Finishing rigging of the boat over the next few days
Wed Nov 25, 2015 6:26 pm
I pull 14' with my 23 and the stock pump, no issues whatsoever. I have direct connections at the tank and motor.
1744 Phowler Prowler, 23 Dixie
Thu Nov 26, 2015 9:06 am
Users browsing this forum: No registered users and 202 guests
