It is currently Mon Dec 15, 2025 7:17 pm
[ 6 posts ] |
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
 Winterizing Your Motor
How do you all put your motor away when done for the year.
I run the gas out of it, disconnect the fuel line from the motor, empty the gas tank into the truck in spring, remove the plugs and spray some WD40 into the cylinder, turn the key so I barley cycle the piston for lubrication.
Is this how you do it or am I missing anything?
Thanks,
_________________ Phowler Extreme 1848 with 36PDFPR
| Thu Dec 03, 2015 11:54 am |
Will
 Re: Winterizing Your Motor
They dont get put away in the South!
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Thu Dec 03, 2015 12:02 pm |
Andy
Joined: Tue Oct 27, 2015 9:44 pm Posts: 278 Location: Coral Springs, FL
If you have a performance carb make sure you drain the float bowl.
_________________ Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF -Unbaffled VooDoo -Gator Glide G2 with base -Wet Sounds Stealth 10 Ultra V2 -Green LED Courtesy Lights -15" Combo LED Light Bar
| Thu Dec 03, 2015 12:07 pm |
TooTall
Joined: Sun Nov 30, 2014 1:37 pm Posts: 411 Location: Pineville, La
Just for a reference wd40 isn't really a lubricant.. Marvel Mystery oil or something similar would do better. Just take spark plugs out spray a little and let it sit overnight and turn it over in the morning.
| Thu Dec 03, 2015 12:13 pm |
mudder
Thanks, Stock Carb. I always wondered if WD40 was the thing to use.
| Thu Dec 03, 2015 1:30 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
You have done the most important step which is to run it out of fuel. I also like to change the oil and filter before I run it out of fuel.
_________________ so many rivers, so little time
| Thu Dec 03, 2015 4:06 pm |
[ 6 posts ] |
