37 GTR Tiller https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=64802 |
Author: | Badrhino [ Wed Dec 02, 2015 8:00 pm ] |
Post subject: | 37 GTR Tiller |
Hey guys been running my 37GTR just curious is it common for it to try and pin u in the seat while making left hand turns. Turning to the right i have no problems. This is a 2015 i dont think u can adjust the torque tab please correct me if wrong. |
Author: | craig [ Wed Dec 02, 2015 8:58 pm ] |
Post subject: | Re: 37 GTR Tiller |
Yes, it's common. If it's a cast lower unit, no you cannot adjust. If it's a machined lower you can. Does it push towards you really bad when running straight? If so you may need to mount the engine offset an inch or two. |
Author: | Badrhino [ Wed Dec 02, 2015 9:07 pm ] |
No driving straight it's fine. Just turning that one direction. |
Author: | craig [ Wed Dec 02, 2015 9:12 pm ] |
Then you're good. You'll get used to it. When making turns, stand up and use your body to help support the tiller. |
Author: | SirBacon [ Thu Dec 03, 2015 11:58 pm ] |
Mess with how your loading the boat. Mine will do the same if I don't distribute the weight right. For whatever reason it seems to like being right side heavy. It drives me nuts though. If it's loaded even just a little off, I fight the tiller even going straight. I need to look into maybe shifting the motor and see if it will correct. |
Author: | Bernhard1 [ Tue Dec 08, 2015 11:13 am ] |
I have a 2012 35 GTR and i have something similar going on. When going straight and i look back at the motor. It almost looks like my tiller is slightly pointed to the right like im taking a mild left hand turn. Also, i've notice that the rooster tail the motor throws is more on one side than the other... Any ideas? |
Author: | DOT3 [ Tue Dec 08, 2015 6:22 pm ] |
