It is currently Thu Dec 18, 2025 2:25 pm
Reply to topic  [ 4 posts ]
 Predator v twin and backwater longtail
Post Predator v twin and backwater longtail
Trying to figure everything out I need to run fuel from the front to the engine. What is the part list I need so I only have to go to the store one time? Thanks
It is finished
Sun Dec 13, 2015 3:02 pm
Post Re: Predator v twin and backwater longtail
Gas tank with hose nipple connector ( stay away from quick disconnects). Threaded on one end to screw in to the gas pickup.
Enough gas line to reach from wherever the tank will ride to the carb, with about three feet extra.
Water seperator fuel filter with see thru cup and draincock on bottom.
6 hose clamps size of hose (1 clamp at tank, 2 for filter, 2 for primer bulb, 1 at carb.
Primer bulb.
Thread sealant
That should get you going
Mon Dec 14, 2015 7:24 pm
He got you. They sell the hose in 25ft rolls at most auto parts stores. Just buy the whole thing. You'll have about 3-4ft left over, leaving enough for the motor to swing in. So get it to the back of your boat. Add 3 more feet. Bam. Make sure your primer bulb is pretty close to you. 3/8 hose is plenty big for this motor. The fuel filter is 1/4" on the motor. So make sure you tighten your clamp down good. It will seal up fine.
Tue Dec 15, 2015 6:16 am
Thanks for the replies
It is finished
Tue Dec 15, 2015 7:59 pm
