U-joint removal
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=6949
Author:  Joe M [ Wed Jan 06, 2010 3:05 pm ]
Post subject:  U-joint removal
does anyone know how to get the u-joint off of the shaft. I'm trying to take the engine off of a go-devil longtail.
Author:  MaXXis85 [ Wed Jan 06, 2010 3:15 pm ]
Post subject:  Re: U-joint removal
if you are trying to take the joint out of the yoke, you need to know out the C-clips and then use sockets and a hammer to know out the joint. Good luck. Ince you look sat it youll know what to do.
Author:  BROOKS [ Wed Jan 06, 2010 3:16 pm ]
Thats a good querston !!! I figure you could just undo the engine mountin' bolts and pull it away from the shaft ... I don't know fo sho !!!
Author:  EasTexDux88 [ Wed Jan 06, 2010 3:22 pm ]
man that things givin you hell aint she??! just be sure not to pull directly against the shaft. if you take the yoke apart you should be able to use a puller or something to get her off. good luck. them things can get all kinds of seized up! :evil:
Author:  Joe M [ Wed Jan 06, 2010 3:27 pm ]
I've un bolted the engine, taken the set screws out of the u-joint, beat the fu(k out of it with a hammer and broken a punch. Theres gotta be a better way!
Author:  EasTexDux88 [ Wed Jan 06, 2010 3:30 pm ]
u may want to take the yoke apart so you can get the engine in a better position, off the frame. then youl have a lot more room to work with.
Author:  BROOKS [ Wed Jan 06, 2010 3:42 pm ]
Can you like put a pully puller 'round it ?
Author:  MaXXis85 [ Wed Jan 06, 2010 3:44 pm ]
Go rent a balljoint press and you will thank yourself. You will need a 7/8" socket and an impact wrench and go to town.
Author:  Joe M [ Wed Jan 06, 2010 3:55 pm ]
I'm about to go rent a cuttin torch and make me some trot line weights!
Author:  EasTexDux88 [ Wed Jan 06, 2010 3:59 pm ]
Author:  Capt. Jon [ Wed Jan 06, 2010 4:25 pm ]
Author:  Joe M [ Wed Jan 06, 2010 5:13 pm ]
VICTORY!!! thanks, capn j.
Author:  BROOKS [ Wed Jan 06, 2010 7:44 pm ]
NICE Job Capt on that .... have you showed yore son that trick yet ??
:lol:
I thot he was tryin' to git the yoke off the engine drive shaft is what I thot ...... what a dumb-butt reader I am ...... :oops: :lol:
Just another way us MMT fellers jump in there and help .... short-tail .. long-tail ... and in some cases ... soft-tail .... we are here to help !!!!
:lol:
