It is currently Sun Aug 03, 2025 6:50 pm
Reply to topic  [ 20 posts ]
 Gator-Tail Maintenance - How to
MMT Moderator
Okay, after the request of a few I have went ahead and made a how to for those that are interested in changing the fluids on the Gator-Tail. The regular schedule maintenance... As you can see the steps take me all of 10 minutes and pumping of the grease out of the lower unit (which is not show but explained in video) takes an additional 5 minutes.
Instead of doing a writeup with pictures I decided to do a video...
The video was filmed by myself so I apologize in advance. The next time I change the fluids I'll redo the video & have someone hold camera so it looks better I ran out of memory card space on the last step but I detailed how to do it so don't think I'm leaving you hanging :lol:
Hope this aids others good luck & if you have any questions just let me know.
You'll need:
-Grease Gun
-1 Tube of AMSOIL Water Resistant Grease for the gun
-ND (Non Detergent) 30 oil for tranny
-5W30 2Q (~1.5 will be used for engine)
-Basic socket set you'll need a 5/8" socket for oil drain plug and 9/16" for the removal of the transmission cover
-Oil Filter
-Phillips head screw driver
-16oz water bottle with bottom cut off (detailed in video) this will catch the oil draining out of the transmission
- Oil fill can (full of the ND30) or something similar that will be able to allow you to get oil into the hole without making a mess!
http://www.youtube.com/watch?v=797shKBeqC4
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jan 06, 2010 6:35 pm
Post Re: Gator-Tail Maintenance - How to
Thanks ;) Great info!
Wed Jan 06, 2010 7:34 pm
Briggs has a new oil filter for the 35.. From what i was told if you use other s voids warranty.>> As for as the reverse oil i just use what ever i'm putting in my motor.. Remember the oil in the trans.. is mostly just for light lube and keep condensation out... Biggest problem with lower unit is people use wrong grease.. the one Gt uses is AMSOIL Synthetic water resistant grease part #GWRCR
17x48 extreme stage 2 GTR
Wed Jan 06, 2010 7:38 pm
Anybody have the new oil filter part number?
Wed Jan 06, 2010 7:50 pm
MMT Moderator
Wed Jan 06, 2010 7:51 pm
Wed Jan 06, 2010 8:07 pm
Great "How To" session.
Are you guys changing the transmission oil at the same time intervals as the engine oil? I'm asking to find out if I am changing it more often than necessary.
Wed Jan 06, 2010 8:59 pm
Location: Drive East until somebody gives you the finger, then drive five hours North.
So when I bought mine, it was the aqua-grease, or aqua-flex, or whatever the hell it's called, that we were supposed to use. I still have tubes of it that I haven't used yet. What's the difference between that and the Amsoil grease? When did they switch to the Amsoil grease? I'm outside of my warranty anyway, so it's not going to affect that.
"Hey! Hey, you little forest creatures! None of you sons of bitches try to be heroes!"
"Once I ate leftover chinese that had been kept in an unsealed container and I experienced complete awareness."
Wed Jan 06, 2010 9:14 pm
Wed Jan 06, 2010 9:29 pm
MMT Moderator
Wed Jan 06, 2010 9:30 pm
Wed Jan 06, 2010 9:44 pm
MMT Moderator
Thu Jan 07, 2010 11:21 am
I changed my oil, trans oil, and filter at 15 hours. Went to dully snthetic 10w30 Mobil 1.
I changed the LU grease about 45 hours and it was still blue as the new grease I pumped in.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Jan 07, 2010 1:13 pm
MMT Moderator
Thu Jan 07, 2010 3:48 pm
Thu Jan 07, 2010 8:04 pm
how often are yall changing the lu grease.
1432 fiberglass inboard with an18 vanguard gettiung where i need to go slowly
F_CK Y__
Would you like to buy a vowel?
Fri Jan 08, 2010 1:12 am
Fri Jan 08, 2010 6:25 am
Fri Jan 08, 2010 7:43 am
MMT Moderator
Fri Jan 08, 2010 10:43 am
o ok thank you i read the post on my phone so i couldnt watch the video but thankyou
F_CK Y__
Fri Jan 08, 2010 2:57 pm
Users browsing this forum: No registered users and 139 guests
