35 GTR Power Trim
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=7312
Author:  km [ Sat Jan 23, 2010 8:40 pm ]
Post subject:  35 GTR Power Trim
Took my boat out for a ride yesterday and on the way in my power trim stopped working. I am getting nothing when I press the up and down button. This motor only has 40 hours on it, anyone have any idea what the problem might be? Going to bring it in to Gator Tail on Monday.
Author:  b_coonass [ Sat Jan 23, 2010 9:06 pm ]
Post subject:  Re: 35 GTR Power Trim
Author:  WestEndAngler [ Sat Jan 23, 2010 9:26 pm ]
The wires came off the back of the switch underneath the trim forward / start cover...?
Author:  craig [ Sat Jan 23, 2010 10:06 pm ]
If your wires are good check the fuse. If it's a tiller model the fuse will be located on the port (left) side of the engine when looking from the back of the boat.
Author:  dead animal [ Sun Jan 24, 2010 8:49 pm ]
Author:  cmelvin [ Sun Jan 24, 2010 9:57 pm ]
i had this same problem happen to me once. the ground wire had became loose so i tightin it back down and had no problems since
Author:  keestan31 [ Mon Jan 25, 2010 8:36 am ]
Author:  BROOKS [ Mon Jan 25, 2010 9:27 am ]
Thay was puttin' a fuse/breaker that looks kind of recktangled on the port side of engine rite by the wirin' harness ..... it be havin' a reset button on it .... mash it and see what you gots.
Author:  MaXXis85 [ Mon Jan 25, 2010 9:41 am ]
My trim has not worked a few times. Everytime it has been a loose connection at my battery. Things loosen up with the vibs. If you have relays in the battery box check to make sure they are good, because they are for the Trim.
Author:  quackconsumer [ Mon Jan 25, 2010 11:22 am ]
Check your connections at da switch and at da battery. Also check da fuse and try da reset button. If it still don't work check your relays by by-passing da power straight to your trim motor. If you still don't have anything bring to GT I had da motor for my hydrolic trim go out on me once and they replaced my trim in about 20 minutes.
Author:  km [ Tue Jan 26, 2010 7:16 am ]
Thanks for all of the responses. I will check it out when I get back home on Thursday.
Author:  km [ Mon Feb 08, 2010 12:30 pm ]
Traced the wire back to a little box that was hanging by a wire. The nut had fallen off. Put a locknut on it so that dosent happen again.
Thanks for all of your responses.
