It is currently Sun Aug 03, 2025 3:10 pm
Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
 bar on the pro drive frame
Post bar on the pro drive frame
[list=]Is there any reason for this bar on the frame being longer than the one next to it? I know on my last PD that long bar had a piece of chain welded to it but this one doesnt. Just wondering if there is any reason for it being tall and when it gets bent from hitting too many stumps it then begins to rub against the motor. can i just cut that mofo off about the same height as the other?
someone enlighten me please.
[/list]
Sun Feb 14, 2010 2:44 pm
Post Re: Any reason for this bar on the pro-drive frame?
if u can't figure out wtf the bar is for, do u think u are smart enough to drive the motor? i'm thinkin no.
:mrgreen:
Sun Feb 14, 2010 7:14 pm
:lol:
18x48 Charles Leonard / 36PD
Sun Feb 14, 2010 7:21 pm
BUNDY BUILT SKIFFLESS
cuz der bad ass like dat....
bunnny rabbit customs.
Sun Feb 14, 2010 7:26 pm
Sun Feb 14, 2010 7:38 pm
Sun Feb 14, 2010 8:09 pm
Sun Feb 14, 2010 8:16 pm
Sun Feb 14, 2010 8:26 pm
Sun Feb 14, 2010 8:34 pm
i know the bar is there as a stop. that is why its bent up so bad. my question is does it need to be that high? because it rubs against the motor. and i didnt say i was going to cut it all the way off, i said i would cut it the same height as the other. might want to read the question correctly before smarting off. just a thought
Sun Feb 14, 2010 8:35 pm
Sun Feb 14, 2010 8:38 pm
I bent mine several times and eventually it did the same problem Owen is having with it making contact on the engine block. I bent mine back with a cheater pipe which was not easy until it quit contacting the engine block.
I do not know what the repurcussions of cutting it the same height as the other would be. I am curious as to why PD has designed one longer than the other.
The bar is removable/replaceable, but others have posted in previous threads that either they couldn't beat the bar out, or it was extremely difficult.
Owen, why not call PD and ask them the best course of action? I am certain they deal with this all the time.
Sun Feb 14, 2010 8:40 pm
Sun Feb 14, 2010 9:15 pm
Post Re: bar on the pro drive frame
Hey I thaught it was a pretty good question. Knew it had to be there, but what can be done to prevent damaged caused?
Drew some good answers.
There`s one thing I`m sure of, and thats that those that are niggerin this thread, will be ones complainin about others niggerin other threads. :roll:
17x48 EXCELL/36PD
Sun Feb 14, 2010 9:48 pm
Mon Feb 15, 2010 5:23 am
If you are running your motor in certain shallow water areas with alot of solid debris you will not be able to prevent the kickback bar from being bent. It's sole purpose is to get the shit knocked out of it. Actually, that can happen in deep water as well. It just depends what is underneath you cannot see. The time I bent mine to where it was rubbing on the engine block; I hit something so hard it was either a concrete or timber piling at WFO. Motor came up hard and gov. kicked out and all. I shut down and inspected everything and caught my wits, and picked up a couple of filling out my teeth. :shock:
If you cannot bend it with a cheater, cut it down or knock it out and replace it. Come to think of it I will cut mine down, the higher side is a safety hazard IMO because if it contacts the engine block it can cause steering problems, and to me that's an issue.
Mon Feb 15, 2010 8:06 am
Mon Feb 15, 2010 9:17 am
if you try to bend it straight with a cheater bar, get your wife to sit on the cavitation plate to hold the motor down. I have a funny story about a prodrive, and ex-girlfriend, and a cheater pipe. :lol:
24x60 Dual Prodrives
Mon Feb 15, 2010 9:31 am
im bout to take that sucker to the shop and cut it off around the same height as the other.
Mon Feb 15, 2010 9:55 am
Mon Feb 15, 2010 10:10 am
AS I SAID BEFORE, IF UR TOO MUCH OF A NUMBNUTS TO UNDERSTAND HOW THE MOTOR WORKS, PLEASE SELL IT AND GO BUY A STEEL BALL AND A RUBBER HAMMER.
THANKS FOR THE PM'S, BUT I AM NOT HERE TO TUTOR THE OBVIOUS.
methinks river is correct about this place.
Mon Feb 15, 2010 10:31 am
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Mon Feb 15, 2010 10:32 am
I'm not cutting bar all the way off, just down to the same size as the one next to it. How is this sailing over peoples heads?
Mon Feb 15, 2010 10:49 am
Mon Feb 15, 2010 11:06 am
dislexia, huh? that might explain alot. :)
Mon Feb 15, 2010 12:36 pm
the way I see it, those fellers at ProDrive are pretty damned smart. if they made it that way, they made it that way for a reason.
Mon Feb 15, 2010 1:44 pm
maybe they use the same bar regardless of power trim or manual trim and just weld that little piece of chain on for the manuals???? who knows? definetly not me :lol: all i know is that bar is now the same height as the other and doesnt rub the engine block :mrgreen:
Mon Feb 15, 2010 1:54 pm
Mon Feb 15, 2010 1:57 pm
Mon Feb 15, 2010 1:58 pm
It's called Job Security. They do it so idiots like yall call and ask them what it's for and in return get to keep their job for another day :D
Pro Drive m'fers
Mon Feb 15, 2010 2:00 pm
Mon Feb 15, 2010 2:05 pm
Mon Feb 15, 2010 2:08 pm
back on topic for a short second
new and improved :D
Mon Feb 15, 2010 2:20 pm
Ummm, anyone ever thought of loosening the set screw and rotating the bar 180 degrees where it's bent towards the front of the boat rather than getting a hernia using a cheater bar? :shock: :shock: :lol: :mrgreen:
Tue Feb 16, 2010 9:20 am
Quit making sense...you wil tip MMT off it's axis :lol:
right now there is a deafening symphony of South LA heads being scratched :lol: :lol:
Tue Feb 16, 2010 9:48 am
Tue Feb 16, 2010 9:55 am
Tue Feb 16, 2010 10:10 am
Dats why NASA pays his big waterhead mucho dinero. :lol:
Tue Feb 16, 2010 4:22 pm
Users browsing this forum: No registered users and 130 guests
