It is currently Fri Aug 01, 2025 9:19 pm
Reply to topic  [ 8 posts ]
 Mud buddy hyper trailering
Post Mud buddy hyper trailering
Just recently bought a hyper drive and was woundering the best way of trailering?
Sat May 29, 2010 8:49 am
Post Re: Mud buddy hyper trailering
I usually trailer mine on the boat. :lol:
Nah, seriously tho, depends on what yr, and model it is. The newer models have "trailering brackets" that make it a lil easier on ya. The older "Hyper Drive" models had to be tied down like a lt.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat May 29, 2010 2:12 pm
I use the travel lock on mine and I also put a ratchet strap around the rear housing and conect it to the boat to keep it from bouncing
Sat May 29, 2010 2:22 pm
Instead of the strap, i cut a piece of 1/2 plywood about 3"x 9" that i put into the bottom of the trim track when trailering. Trim up until it puts enough tension not to bounce.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat May 29, 2010 4:13 pm
Use travel lock with pin in it, trim down to apply some pressure and drive.
I do use ratchet straps from skeg to transom tie downs if I know I will be on a really rough road or if I am travelling a really long distance. Not really needed (depending on your boat) but a habit.
Sun May 30, 2010 5:35 am
Well it's a 03 hyper drive 29 horse..it looks like there is a bracket for a trailering option but don't think it has it.where would the lock pin be located any pictures of it?the transom on the boat isn't the strongest either motor is a little heavy for boat need to replace wood and stiffen it up. am worried about all the weight bouncing when driving.
Sun May 30, 2010 10:27 am
I was talking about the travel lock on the newer motors. I don't think MB made a SD in '03.
Sun May 30, 2010 10:34 am
yeah mine don't have that. not sure exactly on the year but the motor is a 03 so just assumed the whole thing is a 03...
Sun May 30, 2010 8:56 pm
Users browsing this forum: No registered users and 62 guests
