It is currently Tue Jun 24, 2025 3:49 pm
[ 6 posts ] |
Donot seem to be charging
hailcall1
The engine Does not seem to be charging my battery. I have a 35 vanguard and I can charge the battery till its full and it holds it for days, no problem. Go to the lake and i starts great, run around, starting and stopping and then all the sudden the battery is to dead to roll the engine over fast enough to start the engine. One time it just shut off completely while idling.
You guys ever had this. Its a year old.
Fri Oct 02, 2009 5:15 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: Donot seem to be charging
Fri Oct 02, 2009 5:47 pm |
LA OUTLAW
Joined: Mon Mar 02, 2009 9:25 pm Posts: 1096 Location: Morgan City
Do you let the motor idle alot?? If so the motor is not charging the battery while idling, it starts charging around 2500 rpm..
_________________ 1754 GT EXTREME 37EFI
Fri Oct 02, 2009 5:58 pm |
hailcall1
Good article, thanks.
Fri Oct 02, 2009 6:04 pm |
anotherred
What size starting battery are your running? Are you running anything off of it? How old is it and have you have it tested lately?
Fri Oct 02, 2009 7:00 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
put a meter on your battery and see what your base voltage is. Next start the engine with the meter still connected and rev the engine up over 2000 rpms. You should see the voltage go up to 13 or 14 volts.
_________________ BUCK OFAMA
Fri Oct 02, 2009 7:20 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 161 guests |
