It is currently Sat Dec 20, 2025 6:32 pm
Reply to topic  [ 55 posts ]  Go to page Previous  1, 2
 Yet another Briggs case gasket option
Post Re: Yet another Briggs case gasket option
Tue Mar 18, 2014 1:38 pm
Tue Mar 18, 2014 1:51 pm
Tue Mar 18, 2014 2:08 pm
Just because when its 100 degrees the thinner oil starts to pour out of my crank case. And rotella is cheaper and has more zinc. Mobil 1 is awesome oil but its just too expensive for me to let it run out if the gasket. And no, just regular rotella.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Tue Mar 18, 2014 2:25 pm
So you switch to a 20w-50 rotella? Why not just use a 20w-50 synthetic?
Tue Mar 18, 2014 2:29 pm
Tue Mar 18, 2014 2:30 pm
Rotella is the best oil for these flat tappet cave man engines. They're not like your newer truck, you're wasting money on everything else. Older engines with the same style cams like the old Muscle cars that still run today cannot run the newer oils, they've switch to the higher zinc diesel oils.
Tue Mar 18, 2014 2:44 pm
Sbc chevy cam and a 35 briggs cam. Each with a bad lobe. Just a nice synthetic is not enough. The cam has to have lots of zink to live. API rating "SN"is low zink and high enough detergent to clean off any zink it used to have. In my experiance anyway
Tue Mar 18, 2014 10:33 pm
The reason I use 15w-40 rotella is because of the high zinc content. I've always used it to break in new engines and ran it in them if possible. I just don't use it in the winter because its too thick for a lawn mower engine in cold weather.
Wed Mar 19, 2014 7:19 am
I run Rotella in mine year round.
Wed Mar 19, 2014 7:53 am
Post Yet another Briggs case gasket option
^^^^^ x2 all year long rotella 15-40
Sent from my iPhone using
Wed Mar 19, 2014 10:05 am
Alright, somewhere I said T6 but I use Triple T Rotella, the T6 is just their Synthetic line which would probably be good too. The Triple T however is the conventional that I know has a lot of zinc in it. You can get it in 10W-30 or 15W-40, I prefer the 15W-40. It never gets below zero where I live but it does get hot.
Thu Mar 20, 2014 4:59 am
^^^ this is the good stuff, and cheap too!
Thu Mar 20, 2014 6:01 am
So will now u change ur mind............ :lol:
Thu Mar 20, 2014 11:58 am
Thu Mar 20, 2014 12:18 pm
