It is currently Sun Aug 16, 2026 12:14 am
Reply to topic  [ 25 posts ]
 Torque specs/valve clearance specs
Post Torque specs/valve clearance specs
Can someone tell me right off hand the cylinder head and rocker arm bolts torqe specs for a 36pd also valve clearance specs? Thankx.
Sun Oct 24, 2010 8:57 pm
Post Re: Torque specs/valve clearance specs
Mon Oct 25, 2010 5:41 am
Gary, thanks. I'm gonna put da bookmark on dis.
Mon Oct 25, 2010 9:02 am
Mon Oct 25, 2010 4:21 pm
Deadbird8: link to those values? Does anyone have a link to a detailed manual with these specs and instructions for installing heads, porting and polishing intakes, decking heads as these procedures apply to vanguard engines? I can find generalized manuals but none have the depth and breath of information for which I am looking. Any help...links, publishers, online retainers, titles would be very helpful. Thanks in advance.
Mon Oct 25, 2010 6:34 pm
Bump.... I need a manual. Help. Thanks
Tue Oct 26, 2010 8:06 am
Tue Oct 26, 2010 8:18 am
x2 Briggs may even have a service manual in pdf format on their website. Kohler does. If not, order one... There's not gonna be any info on modifying the engine though, so nothing about porting then intake.
Tue Oct 26, 2010 8:41 am
Tue Oct 26, 2010 9:22 am
If anyone knows it would be DB8... I've looked for some stuff on the briggs site before, like you said, its tough.
On another note, the kohler site is very easy to navigate. For those of you running kohlers, check it out. They have all the parts lists, owners manuals, and service manuals online...
Tue Oct 26, 2010 1:05 pm
Repair manual is orderable from briggs or others, I got mine from Jacks Small Engine. - it has a Briggs part number. I have not seen one on-line. Briggs doesn't have 'manuals' for modifying the engines (decking heads etc...)
If you are changing the heads then the manual is not gonna help you much except for torque sequence for the heads (which only shows 5 bolts instead of 6 in the diagram anyway). It doesn't go into step by step detail about pulling off the cowling etc... You would would need a 10mm, 12mm, 13mm, 14mm, Torx T40, and torque wrench. Take off the fan cage etc.., cowling, intake, valve covers,exhaust, then air baffle shields, and finally the 6 bolts for the head.
Porting the stock intake- I did a long post with pictures on the site that can't be named that gives a step by step. But they block that site here or I would post the link.
Fri Oct 29, 2010 1:59 pm
Marked!
Thu May 31, 2012 12:36 pm
Any one know the torque spec for the clutch bolt? (At least that's what I think it's called....the bolt that goes into the clutch and hold everything to the shaft) Thanks.
Fri Jul 12, 2013 7:31 am
Call peck and verify, but I want to say its around 70 ft lbs.
Fri Jul 12, 2013 7:47 am
Fri Jul 12, 2013 8:17 am
Think its more than that. Impact that sucker
Fri Jul 12, 2013 8:50 am
Sent an email to Micah at MB and he said 55 FT Lbs.
Mon Jul 15, 2013 2:11 pm
I thought this was still about a PD!? :lol:
Mon Jul 15, 2013 2:21 pm
Sun Nov 08, 2015 3:15 pm
Hardie he posted that 5 years ago.
Sun Nov 08, 2015 5:40 pm
Sun Nov 08, 2015 7:52 pm
Can somekne tell your how to fuckin type and make sentences?
Sun Nov 08, 2015 8:24 pm
Mon Nov 09, 2015 2:58 am
Tough crowd up in this bitch! Hahaha
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Sun Nov 29, 2015 6:43 pm
Mon Nov 30, 2015 1:43 pm
