It is currently Thu Jun 26, 2025 11:54 pm
Reply to topic  [ 3 posts ]
 Coil Crazy need help!
Post Coil Crazy need help!
18 HP Vanguard.... Can't shut it off when running on two cylinders. To stop/ground terminal I have the black switch wire and the kill switch wire. From the coils (2) I have a wire with resistors that also runs to the stop/ground. They are supposed to be linked together with reisiters in between. When I do this it only runs on 1 Cylinder. Take one off and it runs on 2. Kill switch will only stop engine when running on 1 Cylinder. Key switch does not shut off engine at all. ???? Is it the ignition switch that is causing this or something else???
Thu May 07, 2009 2:27 pm
Post Re: Coil Crazy need help!
start at ur key switch and follow all wires, if they go to the starter for example then follow where they go. keep following untill u look over all of them....bet one is burnt
Thu May 07, 2009 6:11 pm
Wiring harness. The kill switch not killing it doesn't have much to do with your key switch. My opinion.
Thu May 07, 2009 9:58 pm
Users browsing this forum: Google [Bot] and 97 guests
