| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| Drag Specialties Throttle https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3018 |
| Author: | T-mac [ Tue Jul 07, 2009 8:03 am ] |
| Post subject: | Drag Specialties Throttle |
Can one of you fellas running this setup take some "detailed" pics of the linkage and routing of the cable etc on a PD Appreciate it |
| Author: | aucoin [ Tue Jul 07, 2009 8:10 am ] |
| Post subject: | Re: Drag Specialties Throttle |
| Author: | BradS [ Tue Jul 07, 2009 9:45 am ] |
| Author: | RC [ Tue Jul 07, 2009 1:51 pm ] |
Moved my choke to a hole I drilled on the other side of keybox, then ran the cable through that hole, no real reason why. Black taped the cable to the tiller tube, also taped up the end of the tiller so the core didn't spin. Put some tape on the cable by the valve cover to keep it from gettin chewed up. |
| Author: | Brinkleydog [ Wed Jul 08, 2009 8:37 am ] |
If you are close to EVT you can go over and look at my setup. It is almost exactly like RC. What i did to stop the factory SS shaft from moving is drill a 5/16" or so hole into the factory stop block and placed it over the factory pin stop. This picture sucks but its the first one i found on the web. Hope this helps. BB whay kind of setup you got going over your way? |
| Author: | RC [ Wed Jul 08, 2009 5:45 pm ] |
If I coulda found my bigger holesaw I woulda used it. Figured more air flow couldn't hurt anything. No pilot holes in the block either. |
| Author: | Full Throttle [ Wed Jul 08, 2009 8:19 pm ] |
RC, Just curious.... Isn't your choke on the Mikuni carb? Wondering why you re-attached the old choke on the other side of the key box? I like that set up. Is throttle response better? Where do you find the kit? Thanks. |
| Author: | bayouboy [ Thu Jul 09, 2009 6:00 pm ] |
| Author: | RC [ Thu Jul 09, 2009 8:29 pm ] |
-I hadn't got around to removing that old choke puller yet. -Not really a kit, just a drag specialties twist grip for an old style harley/mikuni setup. Custom length cable from motion-pro in CA somewhere (52", like $40 or so). |
| Author: | Duck Natzi [ Thu Jul 09, 2009 8:59 pm ] |
is it worth doing ? that much better ? |
"will it make me go faster ? " River |
| Author: | RC [ Fri Jul 10, 2009 6:57 am ] |
| Author: | bayouboy [ Sat Jul 11, 2009 6:31 pm ] |
| Author: | Duck Natzi [ Sun Jul 12, 2009 3:15 am ] |
where can you buy one ? |
| Author: | bayouboy [ Sun Jul 12, 2009 7:28 pm ] |
| Author: | bayouboy [ Tue Jul 14, 2009 5:43 pm ] |
Pics update. This is Willets setup on my motor. Throttled up Throttle cable run, no cable clamps the sleeve floats between the sockets and is held in place by the carb spring tention. |
| Author: | OwenDickeson [ Tue Jul 14, 2009 7:29 pm ] |
what is your motor coated in bayouboy? |
| Author: | bayouboy [ Tue Jul 14, 2009 8:46 pm ] |
Liquid wrench lub. oil. Its about the best thing I found todate (locally). It stays on and doen't evaporate. http://www.gunk.com/lubricants.asp http://www.gunk.com/prod_photo.asp ............................... |
| Author: | Full Throttle [ Thu Jul 16, 2009 12:59 pm ] |
Does Willet or anyone else sell the one you are using BB? |
| Author: | gooseklr [ Sun Jul 26, 2009 3:40 pm ] |
I need one of these for my PD 36 with a stage 3. Where can I purchase one, or is it possible someone has a extra I could purchase? Thanks Gooseklr |
| Author: | BradS [ Sun Jul 26, 2009 3:58 pm ] |
BB actually made these. Might wanna PM him about em |
