It is currently Tue Jun 24, 2025 10:35 am
Reply to topic  [ 27 posts ]
 IN NEED OF A MIRACLE
Post IN NEED OF A MIRACLE
Bought the EVT mikuni carb kit w/ intake.... installed it saturday and went ride sunday. Not performing, Im only turning 3700 RPM's wide open, wanting to bog down and kill when going from no throttle to wide open everytime, and only getting power response from no throttle to half throttle where i turn 3700 RPM's. I am fed up with it and dont know what to do anymore!! any help would be appreciatted!! tryin to get in touch with coondik @ the moment, anyone know how to contact with him??
18x46GTB W/ 35GTR.....
"Sneaky Stage" sponsered in part by LiL Daddy Customs
Rated "Rahhhh"
Mon Sep 07, 2009 7:25 pm
Post Re: IN NEED OF A MIRACLE
Are you still running factory exhaust? That may be the problem.
Never mind don't listen to me. I'm likely to phuck your shiat all up.
Bayouboy, Rod, and all you other smart people...........Help him out will ya.
Mon Sep 07, 2009 7:30 pm
Take it to COONDIK...
Mon Sep 07, 2009 7:51 pm
does it only get 3700 out of water?
Call EVT 300 time they will answer eventually......LOL
Mon Sep 07, 2009 7:58 pm
I want to try and let coondik mess with it and let him work my heads, but i need his number to get in touch with him! Where is he located?
Rated "Rahhhh"
Mon Sep 07, 2009 8:01 pm
Mon Sep 07, 2009 8:02 pm
He is located on the old hwy in Morgan City at Redfish Rental his number is 9853970004...
1754 GT EXTREME 37EFI
Mon Sep 07, 2009 8:03 pm
Mon Sep 07, 2009 8:08 pm
Buuuuuuurrrp! exscuse me! whooooo that felt good! smack, smack, smack? taste funny though!
Mon Sep 07, 2009 8:09 pm
I have the EVT exhaust, 3700 in the water with Mikuni carb and EVT intake... I was turnin 3850 with the stock carb and intake! Dunno what the hell is goin on.... Never heard of anyone havin problems like this.... I guess im just a dumb a** when it comes to the big block.... I bought the stuff from kyle @ GT and all he gave me was the intake, carb, air filter, pre-filter, boots, and bolts. No jets or needels
Rated "Rahhhh"
Mon Sep 07, 2009 8:12 pm
Mon Sep 07, 2009 8:14 pm
Coondik will fix you right up padna!!!!!
Mon Sep 07, 2009 8:18 pm
12x11pitch power tech that came on her from GT.... Keep it coming, i appreciatte all the help fellas..... Amazing how the mud motor runners stick together!
Rated "Rahhhh"
Mon Sep 07, 2009 8:20 pm
FT had the same problem a few weeks back. He had a bent tab on the carb and was not getin full travel.
Mon Sep 07, 2009 8:39 pm
I had the same problem on the low end power. I tried all the jets and needles they make. I finally did away with the evt intake and got the bps adaptor and my problem was solved. As for your top end power you need to see what main jet is in the carb and what notch your carb needle is on.
With just exhaust on your engine it most likly will be a lil slugish. Your gonna need head work and maybe even a timing key. Its seems on the gator tails there is a bad bog from idle to WOT on lightly modded engines. I had this same talk with Hoyt at Gator tail about the EVT intakes. He confermed what I already thought. The engine doesnt pull in enough air at idle to WOT to accomidate the big intake. This means the air isnt moving fast enough. Im guessing to get the boat moving you have to roll the throttle slowly. I bet it bogs down getting on the trailer also.
The prodrives dont seem to have such a problem with it. It could be the gear ratio. It is lower on the prodrive so its not as hard for the engine to get the prop turning.
BUCK OFAMA
Mon Sep 07, 2009 8:56 pm
you also need to plug up the two vacum tubes on the carb. They are the two barb fittings on the outlet side of the carb. They will make it run very lean.
BUCK OFAMA
Mon Sep 07, 2009 9:09 pm
Mon Sep 07, 2009 9:55 pm
BUCK OFAMA
Mon Sep 07, 2009 10:03 pm
Nah.... Looked @ it will riding yesterday and whatever i did with the throttle, where the cable connects to the carb, it reacted. But anything after half throttle was pointless. I'll be on the line with hoyt, coondik & andy @ the boat doctor and i GARAUNTEE that this problem will get resolved. Im tired of messing with it and gonna let the pros get to the bottom of it
Rated "Rahhhh"
Mon Sep 07, 2009 10:16 pm
Take a can of starting fluid and spray around where the carb mounts to the intake and where the intake mounts to the engine. If it revs up you have a leak.
Tue Sep 08, 2009 2:28 am
relax buddy, i'm sure the answer is lookin' right at u! first thing u need to look at is what you have changed from before to now. these guys have already steered you in the right direction. i have had issues with carbs not being jetted right from the factory and intakes flanges not quite mating up to the heads. although, most of this has been covered in prioir replies, here is a step by step run down on how i would ckeck it out.
1. intake: make sure flanges are mounted flush with the heads and the gaskets are somewhat crushed (be sure they are not over-tightened and have been busted). check the carb flange / adapter boot ( i usually use RTV liberally when installing the boot. once the 2 bolts have been tightened, remove any excess RTV and let it dry prioir to installing)
2. carb.: here are somethings i check out on the carb before installing.
A) Main Jet / Idle Jet: remove the float bowl from the bottom of the carb to get a visual on these jets. the main jet is located pretty much dead center of the carb. and is the larger of the 2. you shouldn't have to remove the main jet to see the size. The idle jet is located right behind the main jet. use a flathead screwdriver to remove and inspect. Make sure both jets are fastened securely and reinstall float bowl. (i usually check the height of the float at this time, but we'll come back to this later). as stated before the main jet size should be no less than 155 and no greater than 165. the idle jet size should be 25.\
B) Needle Position: the needle is accessed through the top plate of the carb. It should be set in the 3rd position and fine tuning to it can be done at later time, as with the float.
** remind me to send you the HSR Manual in pdf format, this will expain a lot**
If all these things check out, then install the carb & intake. Connect all the components except for the throttle. Run / test the setup, check the choke, idle rpm's and top end rpm's. make sure there is no "booging" or flat spots throughout the rpm range
3. throttle linkage: this is pretty staright foward. connect throttle linkage, secure outer conduit and take up any cable slack by bending the tab on the carb.
Tue Sep 08, 2009 8:15 am
See that coondik is slicker then owl sh!t..
Tue Sep 08, 2009 11:21 am
Tue Sep 08, 2009 11:36 am
Tue Sep 08, 2009 12:06 pm
Tue Sep 08, 2009 12:16 pm
Tue Sep 08, 2009 5:31 pm
WC Custom 1854
Tue Sep 08, 2009 6:21 pm
Users browsing this forum: No registered users and 124 guests
