It is currently Wed Jun 25, 2025 1:55 pm
Reply to topic  [ 6 posts ]
 Cam Specs
Post Cam Specs
Can anybody tell me the Lift, Duration, LSA @ 50* on the stock cams that come in the 35/ 36 Briggs?
Mon Oct 26, 2009 3:46 pm
Post Re: Cam Specs
Max Lift
Intake .363 Exhaust .357
Duration
Intake 205.8 Exhaust 210.8
Mon Oct 26, 2009 4:37 pm
Post Re: Cam Specs
Any clue what lift the springs are rated for and what about LSA?
Mon Oct 26, 2009 4:55 pm
Post Re: Cam Specs
You're trying to equate these to HD cams and it just doesn't work.. No idea was LSA is or valve timing.. The info Mitch posted is exactly what I got back from Briggs when they profiled another cam against the stock cam.. Even when I had Crane do a custom grind for me they never listed LSA but they did list duration of the final grind.. Stock springs are somewhere around 20# give or take.. The double wounds are around 30-32#.. My cam is about .483 lift w/ roller rockers and with the double coils I never had a bind issue.. Gonna go back to stock rockers and shimmed stock springs and see if they bind when I put it back together next week..
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Tue Oct 27, 2009 6:32 am
Post Re: Cam Specs
Good info, at least you got a response Brad. I posted an exact thread about this a few months ago and No bueno.
LSA should be somewhat easy to find if you have a jig setup to find the highest point on each lobe and measure the LSA from there. LSA= Lobe Separation Angle for those who do not know!
Tue Oct 27, 2009 6:50 am
Post Re: Cam Specs
Tue Oct 27, 2009 9:18 am
Users browsing this forum: Google [Bot] and 124 guests
