It is currently Mon Aug 11, 2025 2:15 pm
[ 3 posts ] |
Blue
Joined: Sun Oct 25, 2009 4:07 pm Posts: 15 Location: Louisiana
 U-Joint running hot
I have an old home made go-devil that I have used for many years with a 8hp and a 12hp motor. This year I put a 16 hp on it and the u-joint runs over 200 degrees. I think the u-joint is in good condition and I tried more grease/less grease. The design is when we ran the angle at 15 degrees because the old small hp motors were slinger lubricated and if you put too much angle the front bearing would starve for oil. I am thinking about taking some of the angle out, any other ideas would be appreciated.
Sat Nov 21, 2009 12:27 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: U-Joint running hot
sounds like our on the right track to me.
_________________ BUCK OFAMA
Sat Nov 21, 2009 2:15 pm |
Boss Moss
Pull the u-joint & check both surfaces for movement. Signs of wear on either may be an indication that you have bad bearings in at least one of the yokes. Even if no signs of wear are evident, changing the u-joint is a pretty cheap start in the right direction. Bad bearing = friction = heat .. Much luck to ya!
_________________ "Don't act like you never pooped in you hip boots!"
Tue Nov 24, 2009 9:55 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 132 guests |
