Oil cooler
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=70276
Author:  timmyt [ Mon Apr 17, 2017 9:49 am ]
Post subject:  Oil cooler
Does anyone have pictures of how they mounted an oil cooler? I have the LRG PS from baker prescision. Just looking for a few ideas. This is for a 35 GTR.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Author:  ibfishinb [ Mon Apr 17, 2017 4:39 pm ]
Post subject:  Re: Oil cooler
Author:  timmyt [ Tue Apr 18, 2017 2:48 am ]
The heat coming off the cooler doesn't effect anything?
Author:  ibfishinb [ Tue Apr 18, 2017 4:42 am ]
Doesn't appear to.
Author:  Quack N Stack [ Tue Apr 18, 2017 10:04 am ]
Might be a dumb question but Whats the benifit of having a larger oil cooler than the factory one? Other than just cooling faster..
Author:  boatguy [ Tue Apr 18, 2017 6:22 pm ]
Author:  MNwingsetter [ Tue Apr 18, 2017 8:04 pm ]
Should add oil capacity too which would lead to longevity I would think
Author:  SCmudder7071 [ Tue Apr 18, 2017 8:52 pm ]
There's my old MB lol
I just did it for looks honestly.
Author:  timmyt [ Wed Apr 19, 2017 7:27 am ]
Author:  CypressCritter [ Wed Apr 19, 2017 7:47 am ]
I would think(3rd grade hard all 3 times)that anything that would help the engine run a little cooler would help and not hurt anything. IMO
Author:  MNwingsetter [ Wed Apr 19, 2017 7:51 am ]
I agree
Author:  ibfishinb [ Wed Apr 19, 2017 2:40 pm ]
I assume added oil capacity and cooler oil by getting it off of block and on the front of the motor.
Author:  cb5331 [ Wed Apr 19, 2017 3:30 pm ]
The one on the bottom pic would not cool as well as stock. That's a different type of cooler. Not as efficient. If you were gonna use one of those, it should be used with the stock cooler, not instead of.
The one that's just slightly larger than the stocker from baker precision can be mounted in the stock location. That's how I had them installed on every motor we put them on. Same type of cooler as you have stock, just a little more capacity, and a little more cooling surface. Totally unnecessary, but cheaper than replacing a broken stocker.
Author:  timmyt [ Tue Apr 25, 2017 1:14 pm ]
Author:  timmyt [ Tue Apr 25, 2017 1:17 pm ]
Would it be better to run the Baker and the stock together?
Engine has mikuni, voodoo,delta heads, 310 cam just trying to make it last a few more hours before it goes bang.
Author:  TPerkins [ Tue Apr 25, 2017 1:20 pm ]
Lol added oil couldn't be but a few ounces. Your also heating preheating the air that's going to go over/around your heads and intake.
Sent from my SM-G930V using Tapatalk
Author:  cb5331 [ Tue Apr 25, 2017 1:23 pm ]
Better to run it with the stocker? Yes. Necessary? No.
With the larger one from baker, the lower two holes mounted in the same location as the stocker. You could make a bracket out of aluminum or something for the top two holes, but I never worried about it. Think I put a zip tie around the body and through the blower housing on ours, IIRC.
