It is currently Tue Nov 24, 2026 2:31 pm
Reply to topic  [ 6 posts ]
 Lower unit question
Post Lower unit question
Hi, I have a 2012 gatortail 35hp motor. I just got it last year so all this is kinda new to me.
I was greasing the lower unit and had what I think is a ton of water flush out.
Is this normal or do I have a seal problem?
[url][https://youtu.be/0mOZfH5r-UE[/url]
Mon Aug 13, 2018 8:06 pm
Post Re: Lower unit question
You need to replace the seals on the propeller end!
Sent from my SAMSUNG-SM-G935A using Tapatalk
Mon Aug 13, 2018 8:44 pm
Shoot me a text again and I’ll walk you through it. Definitely need new seals.
Mon Aug 13, 2018 8:46 pm
Can you send me a PM with your number again please?
Tue Aug 14, 2018 8:44 am
Or just email me at marystandiford at Yahoo dot com
I'm basically being told that we didn't add enough grease to begin with, so water got in and it is normal??
Tue Aug 14, 2018 8:53 am
Because yeah, a seal should be designed to leak. That doesnt compute. I dont doubt you were told that, but I would suggest replacing the seal, make sure its greased properly, and slap whoever told you the seal isnt designed to keep water out unless you add more grease. A little might make it past the seal after a while, but it shouldnt be enough to soak a paper towel.
#TheGhostBoat
Tue Aug 14, 2018 9:16 am
