| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| Lower unit question https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72853 |
| Author: | muddymunsters [ Mon Aug 13, 2018 8:06 pm ] |
| Post subject: | Lower unit question |
Hi, I have a 2012 gatortail 35hp motor. I just got it last year so all this is kinda new to me. I was greasing the lower unit and had what I think is a ton of water flush out. Is this normal or do I have a seal problem? [url][https://youtu.be/0mOZfH5r-UE[/url] |
| Author: | lastchance [ Mon Aug 13, 2018 8:44 pm ] |
| Post subject: | Re: Lower unit question |
You need to replace the seals on the propeller end! Sent from my SAMSUNG-SM-G935A using Tapatalk |
| Author: | bluesky2012 [ Mon Aug 13, 2018 8:46 pm ] |
Shoot me a text again and I’ll walk you through it. Definitely need new seals. Sent from my iPhone using Tapatalk Pro |
| Author: | muddymunsters [ Tue Aug 14, 2018 8:44 am ] |
Can you send me a PM with your number again please? |
| Author: | muddymunsters [ Tue Aug 14, 2018 8:53 am ] |
Or just email me at marystandiford at Yahoo dot com I'm basically being told that we didn't add enough grease to begin with, so water got in and it is normal?? |
| Author: | Russ [ Tue Aug 14, 2018 9:16 am ] |
Because yeah, a seal should be designed to leak. That doesnt compute. I dont doubt you were told that, but I would suggest replacing the seal, make sure its greased properly, and slap whoever told you the seal isnt designed to keep water out unless you add more grease. A little might make it past the seal after a while, but it shouldnt be enough to soak a paper towel. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
