Misfire/back firing 2006 prodrive 36
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73694
Author:  david95 [ Sun Mar 31, 2019 12:52 pm ]
Post subject:  Misfire/back firing 2006 prodrive 36
I have been searching and trying everything I’ve read that I thought it could be. Just put new coils on it, cleaned the carb which is a mikuni, only aftermarket part on it. But it not wanting to run hardly in neutral and definitely not getting anything under load just cutting out and back firing through carb. If anyone could give a suggestion I’d greatly appreciate it!
Author:  Russ [ Sun Mar 31, 2019 1:35 pm ]
Post subject:  Re: Misfire/back firing 2006 prodrive 36
Check valve lash?
Author:  Will [ Sun Mar 31, 2019 3:28 pm ]
Did you set the coil gap on the new ones?
Author:  david95 [ Mon Apr 01, 2019 5:45 am ]
I’m going to check valves today, and I did set gap on the new coils. How do you post a video on here, I can’t figure it out.
Author:  50fps [ Mon Apr 01, 2019 8:31 am ]
Just a though, but it could also be the flywheel key or possibly an air leak?
Author:  david95 [ Mon Apr 01, 2019 3:28 pm ]
Just pulled the valve cover, one is broke haven’t looked a diagram on it yet. But if your looking at the rear of the motor, it’s the left cylinder and top valve.
Author:  david95 [ Mon Apr 01, 2019 3:34 pm ]
I planned on shaving heads already, what should I put in them while I’m at it? Thank y’all for the information.
Author:  DmaxHunter [ Mon Apr 01, 2019 7:03 pm ]
It looks like the top rod is out of the lifter cup. Or am I wrong
Sent from my SM-N950U using Tapatalk
Author:  Russ [ Mon Apr 01, 2019 7:23 pm ]
Author:  Wchauvin [ Mon Apr 01, 2019 7:59 pm ]
Yeah I saw that too. I’m surprised it didn’t bend the rod seated like that
Author:  banded-mallard [ Tue Apr 02, 2019 3:43 am ]
Author:  Will [ Tue Apr 02, 2019 4:56 am ]
Yup /\
Author:  Wchauvin [ Tue Apr 02, 2019 6:15 am ]
If the lash was not set with it like that, then would it bend it or no?
Author:  david95 [ Tue Apr 02, 2019 7:37 am ]
It was the push rod that dropped out, just got a little excited looking at it at first. Gonna get me some oil and a filter today and fire em up this evening.
Author:  JBsuperG [ Tue Apr 02, 2019 8:26 am ]
Great to have a group like this to help out with these kind of things. It is a nice way to learn how to work on these engines and save money.
Author:  banded-mallard [ Tue Apr 02, 2019 8:58 am ]
Author:  Wchauvin [ Wed Apr 03, 2019 9:00 pm ]
Ahhhhh I got ya, thanks for the clarity bro, I appreciate it and understand it better now
Author:  Will [ Thu Apr 04, 2019 6:59 pm ]
Banded get a cookie for that lesson?
The last one is what usually happens, folks don't get the jamb nut tight enough, shit works loose, lash opens up, rod slips out and kink.
Author:  david95 [ Fri Apr 05, 2019 7:44 am ]
We’re riding again, I appreciate all the information I get off of here! Very helpful!
Author:  Wchauvin [ Sat Apr 06, 2019 8:13 am ]
Yeah, thanks again for the info bro
Author:  banded-mallard [ Mon Apr 08, 2019 4:33 am ]
Author:  Will [ Mon Apr 08, 2019 9:31 am ]
Author:  banded-mallard [ Mon Apr 08, 2019 9:39 am ]
:lol:
