It is currently Mon Sep 22, 2025 12:21 pm
[ 4 posts ] |
Gator Tail throttle cable confusion
jreif14
Joined: Mon Feb 11, 2019 12:03 pm Posts: 49 Location: Kenosha, Wisconsin
So I’m a little confused. I have a 23hp Vanguard that I ordered a new throttle cable for, off BPS. The engine is non EFI, so I ordered the “stock” engine end. Well, when I went to swap it out, the engine end on the new cable is different from what the end was on the existing cable, which appears to be a “stock EFI” end, according to the BPS website. The new one wouldn’t stay in the throttle, as it is too small and kept slipping out. As far as I am aware, the motor is stock, besides exhaust. The previous two owners claim it is a "stage 2" motor, but I cannot prove nor deny these claims. Anyone have any idea why this would be?? Thanks in advance!
_________________ 1748 Mike Kliebert with a 37 Prodrive
Thu Apr 04, 2019 7:21 pm |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
 Re: Gator Tail throttle cable confusion
I can't comment on the history of the cables for that motor, but can you just swap it out for the larger one? I mean regardless of whether BPS calls it "EFI" or "stock", I'd just get the one that fits.
When I added a new BPS throttle lever cable to my carb GTR, I modified the handle end and used the existing cable (had to grind it down). If I want to add the new cable, I'd have to drill a larger hole on the engine side (I'm keeping the new cable as a backup).
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Fri Apr 05, 2019 5:43 am |
MaXXis85
GT hast bigger ends and drills the bracket to accommodate it. Yeas the EFI end is the same size as the older GT stock carb setups
Fri Apr 05, 2019 6:30 am |
jreif14
Mon Apr 08, 2019 11:29 am |
[ 4 posts ] |
Users browsing this forum: Schleppy and 1 guest |
