40 briggs cam wear symtoms https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74062 |
Page 1 of 2 |
Author: | dead animal [ Mon Aug 05, 2019 2:56 pm ] |
Post subject: | 40 briggs cam wear symtoms |
hey, what are some of the signs that your cam is wearing out on these 40 briggs motors? mines having trouble turning up a wore prop. it takes it quite a while to achieve full rpm's and hardly ever hits the rev limit anymore. it wants to run 4600 rather than 4800 everywhere unless I trim up too much. hopefully just an adjustment somewhere, but after hearing stories of 40's eating cams, i'm startin to think about it. it still starts fine and runs great, just lost top end performance. the valves lash is ok. |
Author: | Wchauvin [ Mon Aug 05, 2019 8:49 pm ] |
Post subject: | Re: 40 briggs cam wear symtoms |
I don’t know, I did a stage 2 Jeremiah build on my motor so I have no idea. If he still has my old stock 40 cam, do you want it? If so, you can have it for free bro if it helps you out |
Author: | dead animal [ Tue Aug 06, 2019 5:09 am ] |
i'm gonna check out all the usual suspects and see what's what. might be somethin easy. I do appreciate the offer, but motors under warranty, hopefully if it's somethin major it will be covered! |
Author: | Wchauvin [ Tue Aug 06, 2019 6:13 am ] |
No problem bro, they should cover it for sure if it’s something major |
Author: | dpd [ Tue Aug 06, 2019 7:17 am ] |
Just wondering how many hours about do you have on that 40? |
Author: | Will C [ Tue Aug 06, 2019 10:22 am ] |
While setting your valves just make sure the valves have full lift |
Author: | dead animal [ Tue Aug 06, 2019 3:31 pm ] |
I haven't been using it much, only 130 hrs on it. dropped off a prop at Baggy's to get cleaned up this am. lent out my spare, so I won't have a prop to run till I get mine back. lol |
Author: | Will [ Tue Aug 06, 2019 4:31 pm ] |
Valves could be looking like a Cheshire cat by now. |
Author: | bluesky2012 [ Tue Aug 06, 2019 5:33 pm ] |
Author: | dead animal [ Wed Aug 07, 2019 7:53 pm ] |
yea, maybe so. i'll do a leakdown on it when I have some time to play around with it. |
Author: | dead animal [ Fri Aug 09, 2019 8:21 pm ] |
went fishing today. had about a hour run one way in basin. headed home and about 5 min from the landing somethin gave up. I must be a friggin nostradomas. lol when I got it started, it barely runs on one cylinder, but I limped it back to the landing and didn't have to paddle or call for help, so it's all good. fixin to use some of that 3 year warranty here shortly! lol might be somethin simple, might not. |
Author: | Will [ Sat Aug 10, 2019 6:57 am ] |
Sounds like a rolled cam lobe. |
Author: | dead animal [ Sat Aug 10, 2019 2:04 pm ] |
well, just went go poke around motor. pulled plugs. one looks great, one black. put plugs in plug boot spun motor over, and have strong fire on both cylinders. took off air filter and looked for debris in carb. nothin seen. put it back on. so... I got fire, maybe it's a fuel thing. maybe a coil? I put my finger on the sparkplug hole and it was sucking/blowing when I turn it over. I listened to fuel pump and it sounds normal. cranked up motor and it's barely running, sounds like it's on 1 cyl. gonna go mix me a drink and then go pull valve cover on dead side. hey, does Nick Peltier do warranty work? pulled the valve cover. looks like valves are moving. gonna be at the shop Monday morning. |
Author: | brycecheramie [ Sun Aug 11, 2019 5:53 am ] |
Author: | dead animal [ Sun Aug 11, 2019 1:27 pm ] |
I just went go pull the other side valve cover. top push rod all bent up and the other one looks like somebody bit off some of it. guess I found the problem. lol not a briggs fan right now. |
Author: | brycecheramie [ Sun Aug 11, 2019 3:13 pm ] |
Briggs gonna Briggs... Im surprised i called it! hahaha ![]() ![]() |
Author: | Will [ Sun Aug 11, 2019 3:31 pm ] |
They're all Briggs and Shittin... Just a matter of time and what. |
Author: | Russ [ Sun Aug 11, 2019 6:09 pm ] |
Briggs are awesome. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
Author: | brycecheramie [ Mon Aug 12, 2019 5:19 am ] |
Briggs is all shits and giggles until briggs giggles and shits... |
Author: | dead animal [ Mon Aug 12, 2019 10:05 am ] |
2 new pushrods and i'm rolling again. gonna do a valve job later this week. leakdown test showed intake valves leaking like a mofo. love me some 3 year warranty!!!!!!! |
Author: | brycecheramie [ Mon Aug 12, 2019 12:14 pm ] |
Author: | dead animal [ Mon Aug 12, 2019 2:15 pm ] |
yea, 40% leakage on intake. warranty work!!!!! |
Author: | Will [ Mon Aug 12, 2019 4:51 pm ] |
Dayum! Pooof pooof |
Author: | Slick1976 [ Mon Aug 12, 2019 6:49 pm ] |
Did they say what could’ve caused this? |
Author: | bluesky2012 [ Mon Aug 12, 2019 6:58 pm ] |
Author: | Will [ Mon Aug 12, 2019 9:27 pm ] |
The famous Briggs smile. |
Author: | Wchauvin [ Mon Aug 12, 2019 10:59 pm ] |
^ got to love a good Alice in wonderland throwback lol (I have a little girl, so I know these things) lol |
Author: | dead animal [ Tue Aug 13, 2019 1:15 pm ] |
Author: | dead animal [ Mon Aug 26, 2019 7:05 pm ] |
update, looks like uncle briggs might have to get off the pot and hook a brother up. will know more tomorrow. ready to fish!!! |
Author: | Will C [ Mon Aug 26, 2019 10:57 pm ] |
Author: | dead animal [ Tue Aug 27, 2019 6:22 pm ] |
Author: | Will C [ Tue Aug 27, 2019 10:56 pm ] |
Sorry for the loss man, lol. I've had go arounds with them on 40's also |
Author: | dead animal [ Wed Aug 28, 2019 6:25 pm ] |
well, I may be wrong. lol the wear on the cam apparently isn't too bad. my mech just wanted to make briggs aware of it for future reference. got the boat back today. it ran a little rough for a few minutes then cleaned up. actually ran 30 on the gps in front of my camp. lol i'll run the heck out of it and we will see how it does. looks like the valve job has brought back the power. |
Author: | Will [ Wed Aug 28, 2019 7:30 pm ] |
The Cheshire cat strikes again |
Author: | MaXXis85 [ Fri Aug 30, 2019 5:04 am ] |
Author: | dead animal [ Fri Aug 30, 2019 6:28 pm ] |
got .006'' wear on the #2 exhaust lobe. I guess that's not enough to matter? i'm no mechanic. I wasn't gonna wait around for briggs to come look at it. got fish to catch. lol if it gets worse i'll bring it back. that's the bueaty of a 3 year warranty!!!!!! |
Author: | dead animal [ Tue Sep 24, 2019 5:54 pm ] |
well, it ran great for about 10 hours. now it's down on power again. I would not recommend a 40 briggs to anybody who wants a reliable motor. or anybody who wants factory support when they have problems. I've gotten neither so far. |
Author: | bluesky2012 [ Tue Sep 24, 2019 6:32 pm ] |
Author: | Will C [ Tue Sep 24, 2019 7:08 pm ] |
Have u verified she flat now? Could be as easy as a valve adjust. They need to be set bout 10hrs after a valvejob anyway |
Author: | Wchauvin [ Tue Sep 24, 2019 7:13 pm ] |
Knock on wood, I have 95 hours on my stage 2 40 so far with no issues at all. Hopefully it continues. I hope you get your problem fixed my bro |
Page 1 of 2 | All times are UTC - 6 hours |
