It is currently Sun Sep 21, 2025 5:15 am
Reply to topic  [ 3 posts ]
 Kohler CH740 -27hp
Post Kohler CH740 -27hp
On a GDLT, RPMS OOW running 4500-4600. RPMS under a heavy hunting load 2600 at best. Motor is still running really low, but this was not in mud at all, even lower rpms in mud. Still think my linkages are off on this engine. I see no reason an engine can spin those rpms out of water and be cut in half without there being some mechanical issue. Have not done a comp or LDT yet..
Any thoughts before i go tearing into it?
Thu Oct 17, 2019 9:54 am
Post Re: Kohler CH740 -27hp
IM beginning to think I have an intermittent spark problem going on, fairly common on these engines. after some searching Im certain i have a DSAM ignition on my Kohler. Kohler came out with an MDI kit for the coils.
Anyone here have any knowledge of this swap? or improvements made between the two? Going to check spark on my engine next to see if one side is intermittent.
Thu Oct 17, 2019 12:43 pm
I would do the testing u mentioned first. Also pay close attention to the valvelift. The kohler has real valvesprings “hi pressure” to run hydraulic lifters. They will eat cams on the wrong oil
Thu Oct 17, 2019 8:35 pm
