Oil type /weight
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74633
Author:  DuckWelder [ Mon Oct 14, 2019 6:26 am ]
Post subject:  Oil type /weight
35hp vanguard . What oil does everyone like to run for winter?
Author:  Russ [ Mon Oct 14, 2019 6:50 am ]
Post subject:  Re: Oil type /weight
Location?
3 in 1.
#GhostBoat
Author:  DuckWelder [ Mon Oct 14, 2019 9:36 am ]
Author:  Will C [ Mon Oct 14, 2019 10:07 am ]
I like the VR1 10-30 for the real cold stuff
Author:  Russ [ Mon Oct 14, 2019 11:03 am ]
Yep. Will nailed it.
#GhostBoat
Author:  boatguy [ Wed Oct 16, 2019 7:56 am ]
Author:  Russ [ Wed Oct 16, 2019 8:28 am ]
Valvoline vr1. 20w-50 for the first 100 hours or so. On the 10w-30 now.
#GhostBoat
Author:  Wchauvin [ Wed Oct 16, 2019 12:44 pm ]
I run royal purple 10w-30. Been running it for years and always liked it.
Author:  fishaholic82 [ Wed Oct 16, 2019 2:22 pm ]
Rotella T4 hands down the best oil to use. Why waste money on other oils that aren't any better.
Compare them yourself. IMO the difference ain't worth the cost.
http://www.royalpurple.com/wp-content/u ... r-2019.pdf
http://shop.sclubricants.com/pub/media/ ... asheet.pdf
Author:  Wchauvin [ Thu Oct 17, 2019 12:00 am ]
To each his own. I’m a royal purple guy.
Jeremiah said when he tore my engine down, it was one of the cleanest he has ever seen on the inside.
My go devil had over 3000 hours on it, and I always used royal purple.
I’m sure the others are excellent, I just like the royal purple
Author:  JIMMY W [ Thu Oct 17, 2019 6:59 am ]
Amsoil
Author:  DuckWelder [ Fri Oct 18, 2019 6:53 am ]
Author:  fishaholic82 [ Fri Oct 18, 2019 8:57 am ]
Which ever oil you decide to go with, don't change your oil according to the hours. Change your oil according to the color of the oil. Check the oil and be mindful of its color. When it starts to turn dark change it, because it is changing colors for a reason.
Author:  Wchauvin [ Fri Oct 18, 2019 1:14 pm ]
^ this is true.
I usually change mine every 25 hours instead of 50. That way you are safe and you know you arnt running broken down oil
Author:  fishaholic82 [ Sat Oct 19, 2019 7:18 am ]
Author:  Wchauvin [ Sat Oct 19, 2019 10:17 am ]
No, I got your point, I’m just saying that at 25 hours, you are good. I run mine moderately and sometimes hard and it’s always perfectly clean when I change it at 25. But it is a good habit to check it often and if it’s breaking down, change it, regardless of how many hours
Author:  fishaholic82 [ Sun Oct 20, 2019 1:13 pm ]
To say you are always good at 25 hours isn't true though. I have ruined oil in less than 10 hours before. I also have gone close to 50 hours though before needing to change it. Just depends on the conditions that your engine is getting put through.
Especially with modified engines they will run hotter and require oil changes quicker than a stock engine.
Author:  Wchauvin [ Sun Oct 20, 2019 5:05 pm ]
I have been good at 25 hours on all the engines I’ve had thus far, so I’m going to continue that habit. I don’t get stupid with my equipment anyway, so that has been fine for me
Author:  Will [ Sun Oct 20, 2019 5:19 pm ]
Good to 450F
Author:  Wchauvin [ Sun Oct 20, 2019 7:04 pm ]
And not nearly as heavy as vegetable oil on the stomach lol
Author:  dead animal [ Sun Oct 20, 2019 7:43 pm ]
I heard canola was better?
Author:  Wilbur T [ Mon Oct 21, 2019 3:57 am ]
Canola is good, it'll save ya a few bucks an oil change.
Author:  bluesky2012 [ Mon Oct 21, 2019 8:20 am ]
I didn’t like the peanut oil I used. Too many fat people chasing me through the marsh. smelled like Fast food from a mile away.
