It is currently Wed Apr 24, 2024 4:31 pm
[ 3 posts ] |
shooter
Case Gasket Delete
Ready to delete the case gasket on my Briggs 32. I searched for info here previously and see that Will C. and someone else were recommended to do the required machining. Can't seem to find that thread now, though.
I think my PMs might be messed up, I haven't connected in my attempts to get a hold of Will.
I'd prefer to have someone with experience do this, obviously. Can anyone help me get hold of Will, or maybe recommend someone else with similar expertise? I would appreciate it.
Thanks
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Wed Jul 21, 2021 4:01 pm |
Russ
Re: Case Gasket Delete
He'll see this post. Stay tuned.
#CFFITR #mudmotor>physics
Wed Jul 21, 2021 10:22 pm |
Will C
if u strip down the rear cover then send me the cover and crank gear i will machine them for the wet setup. aside from that u need hardened case bolts, pto seal and the shorter oil galley rings. any of those oldies with a gasket are going to leak sooner or later. this will fix that and adds strength to the block
Tue Jul 27, 2021 11:50 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 308 guests |
