nafd54
 Cordura fabric
Does anyone have a good way that they attach grass mats or other types of vegetation to cordura fabric? My new blind is mossy oak shadow grass fabric but I would like to get some grass on top for a better 3D look.
Wed Oct 16, 2013 7:33 pm |
Team Schmo
Joined: Sun Sep 08, 2013 8:05 pm Posts: 814 Location: Montana
 Re: Cordura fabric
Did you try zip ties??
_________________ You can't fix stupid
"As long as the dog hits the water"
" Endorsed by Drake Waterfowl, Dakota Decoy, and Rig 'em Right Waterfowl"
"Stealthcraft Boats Pro Staff"
Wed Oct 16, 2013 7:54 pm |
Docott
 Re: Cordura fabric
The problem will be finding a way to do it that doesn't damage the fibers and cause the material to fray. You could use a hot glue gun, but I doubt that would hold up too well. Could heat up an ice pick or a nail with a torch and poke holes in the material (that way it wouldn't fray) and then use zip ties. Or you could get an upholstery needle (big needle, available at Hobby Lobby or fabric store) and run a loop of string (braided fishing line would be good) and tie stuff on.
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
Wed Oct 16, 2013 8:13 pm |
Puddler45
Joined: Thu May 03, 2012 9:07 am Posts: 1199 Location: Wisconsin's waters and woods
 Re: Cordura fabric
Use forehead as backing then zip tip tie green garden fencing to the frame over the top of cordura then zip tie grass on. Otherwise use a hole punch to make holes to run zip ties through and attach grass perfect holes are better than slits cause they won't continue to rip. Or you can heat up a screwdriver and punch a hole through and it will seal up the edges so it won't continue to rip. There are many ways to skin a cat just use your noodle
_________________ 1744 floating a 23 MBHD Stage 2
Wed Oct 16, 2013 8:27 pm |
nafd54
 Re: Cordura fabric
I was hoping for a miracle glue but that ain't gonna happen. I don't have a frame to attach it to because it is a pull across low profile with holes cut in it for people. I guess I'll just have to poke holes but was hoping to not have to because it is somewhat expensive fabric that I don't want tearing and replacing every couple years.
Thu Oct 17, 2013 5:35 pm |
Bigbuckfever
Joined: Sat May 28, 2011 11:18 pm Posts: 2114 Location: Slinger, WI
 Re: Cordura fabric
Have loops sewn on
Sent from my DROID RAZR using Tapatalk 2
_________________ Every day I'm paddlin' 1848 Gatortail boat and 37 efi GTR.
Thu Oct 17, 2013 6:48 pm |
diddyduck
Joined: Mon Sep 02, 2013 10:24 pm Posts: 2624 Location: ponchatoula, la
 Re: Cordura fabric
torch n a knife it wont fray
nasty
 Re: Cordura fabric
Grommet repair kit. Most permanent solution tbh. Get stainless if u can and spray paint brown when done.
Fri Oct 18, 2013 9:19 pm |
Over the LINE
Joined: Mon Jan 19, 2009 5:22 am Posts: 535 Location: New Orleans
 Re: Cordura fabric
Sewn loops. Look for an awning shop, a sail maker or a boat canvas shop. They all have the equipment to do it.
_________________ 17' CAT 5 with 37 GTR
Sat Oct 19, 2013 8:57 am |
gundog05
 Re: Cordura fabric
Fri Oct 25, 2013 10:18 am |
nafd54
 Re: Cordura fabric
Thanks y'all. I think I am just going to have loops sewed in. Seems the most logical long lasting thing to do.
Sun Oct 27, 2013 6:17 pm |
