It is currently Sun Jul 20, 2025 10:17 am
[ 6 posts ] |
1638 or 1838 go devil skiff
natedawg
Hi I am deciding between either a 1638 or a 1838 go devil skiff...I am leaning towards the 1838
I want to get a prodrive because I want reverse, I know there are lots of motor choices and draw backs but thats what I wanna go with
In my area of the universe it is not easy for me to test drive the boats before I buy so....
Can a run a 36 PD on a 1638 I think I can on the 1838...what do you think I should expect for performance. If I run a 27 PD on the 1638 how would performance be?
2 or 3 guys and hunting load
Thanks for the advice
Tue Nov 05, 2013 3:12 pm |
Bigbuckfever
Joined: Sat May 28, 2011 11:18 pm Posts: 2114 Location: Slinger, WI
 Re: 1638 or 1838 go devil skiff
I believe those hulls have the cut back transom as i was looking at a 1638 last week. The weight of the pd will make that thing squat bad between that and the narrow width. Those hulls were designed with a lt in mind. My question to you is, are they still making them? I haven't seen them on the website in a few years and i never called to check.
_________________ Every day I'm paddlin' 1848 Gatortail boat and 37 efi GTR.
Tue Nov 05, 2013 4:53 pm |
natedawg
 Re: 1638 or 1838 go devil boat
I think I should not have called it a skiff....GD calls it a 1638 go devil boat. Here is the link to them http://www.godevil.com/16x38.htmlsays 1638 is rated up to 25hp and 1838 to 30hp I believe so anyone run a 1638 or a 1838 and can provide me some guidence? Thanks
Tue Nov 05, 2013 6:36 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Tue Nov 05, 2013 7:04 pm |
50fps
If your stuck on a GD and the 36 PD go at least the 1844. For a little more than $800 than the cost of the 1838, the 1856 would be what I would consider. I ran the 36 on a 1844 GD hull and when compared to the Phowler 1652 and my current Geaux 1848 the difference in draft wasn't a big issue (maybe 1"-1 1/2") at the most with similiar loads, the benefit was that it turned on a dime and the bottom of the transom didn't dig in as bad.
Thu Nov 07, 2013 12:40 pm |
Chackbay
Joined: Sun Apr 04, 2010 7:37 pm Posts: 39 Location: Chackbay, La
Im running a 16x38 GD hull with at 25 GTR strapped to the back. It sits low in the water bc of the weight but it moves really good with 2 ppl. I would go with a 18x44 if you want to put a 36PD on it since the PD is a little heavier than a GT
Sun Nov 10, 2013 8:25 am |
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 89 guests |
