It is currently Sun Jul 20, 2025 6:18 am
Reply to topic  [ 30 posts ]
 Stringers
Post Stringers
Building a boat from basically stretch and had a couple questions. On longitudal stringers what is the best choice?
I see most mud boats run 2x2 square but most airboats run t bars. Just curious what the strongest shape stronger would be.
Wed Oct 23, 2013 6:27 pm
Post Stringers
1x2x1/8. Or 2x2x1/8. I've seen some guys use hat channel too. But don't recall seeing a mud boat with t bar.
How big is the boat going to be?
Sent from my beeper.
Wed Oct 23, 2013 7:09 pm
Post Re: Stringers
Boat is 1860 slick bottom flat fronted. Boat will either outboard or outboard jet.
But I have found more useful info on building them and idea on this site so I joined even tho it's not a mud rig.
Wed Oct 23, 2013 7:43 pm
Post Re: Stringers
Using 1x2 on the boat I'm building
Wed Oct 23, 2013 7:58 pm
Post Re: Stringers
Wed Oct 23, 2013 8:00 pm
Post Re: Stringers
2 piece. How many 2x2 in a 60 inch floor and are any cross bracing required that aren't touching the bottom of boat?
Wed Oct 23, 2013 8:42 pm
Post Re: Stringers
Wed Oct 23, 2013 10:05 pm
Post Re: Stringers
Thu Oct 24, 2013 4:16 am
Post Re: Stringers
All depends where he's running. The marsh down south you could get away with 5. The stumps in y'all and Owens area 7 or more. He did say he was putting an outboard right? Just guessing he won't be running alot of stumps
Thu Oct 24, 2013 6:40 am
Post Re: Stringers
Yes seemed down the middle.
Ok I was thinking seven or eight would do. Just want plenty of strength as I wanna keep this boat a long while.
And yes an outboard. I live northeastern Oklahoma. Not crazy amount of stumps but we are kinda gentle.
Thu Oct 24, 2013 7:32 am
Post Re: Stringers
Thu Oct 24, 2013 7:33 am
Post Re: Stringers
[quote="Shieldsz"]Yes seemed down the middle.
And yes an outboard. I live northeastern Oklahoma. Not crazy amount of stumps but we are kinda gentle.[/quote
Go with 7 so you have one down the middle on top of you seam.
Thu Oct 24, 2013 7:56 am
Post Re: Stringers
Thu Oct 24, 2013 8:20 am
Post Re: Stringers
Only issue with the one right in the middle is they folded the lip back and welded it that way, so there's a seam right in the middle on the inside. I guess I could use channel over the top or cut the bottom out of a square to lay over it.
Thu Oct 24, 2013 1:54 pm
Post Re: Stringers
Thu Oct 24, 2013 2:25 pm
Post Re: Stringers
How much strength would be lost by going with 1.5" square?
Can get a discount on that size for ordering a bulk quantity.
Fri Dec 06, 2013 6:01 pm
Post Re: Stringers
Not enough to worry ab
Sent from my iPhone using
Fri Dec 06, 2013 6:14 pm
Post Re: Stringers
I've heard of people using hat channel for braces. Says its just as strong and lighter.
Sat Dec 07, 2013 5:04 am
Post Re: Stringers
Sat Dec 07, 2013 7:13 am
Post Re: Stringers
hat section is strong and a good bit lighter .64 lbs. per ft.- 1x2x1/8 tubing .809 lbs. fer ft.- 2x2x1/8 tubing 1.103 lbs. per ft. even using 11/2x 1/8 tube still weighs .809 a ft. 11/2x2 is what some builders use laid flat with the 11/2 vertical and 11/2x2x1/8 is .956 fer ft.
Sat Dec 07, 2013 8:52 am
Post Re: Stringers
Not to steal the thread, but whats the best way to roll bend 1x2 rec tubing?
Sat Dec 14, 2013 12:28 pm
Post Re: Stringers
With a tubing roller
Sat Dec 14, 2013 12:55 pm
Post Re: Stringers
Sat Dec 14, 2013 4:07 pm
Post Re: Stringers
I tack my braces together on the ends and one time in the middle. Use a set of plate rolls and roll all of them at one time. And I make a template out of 3/4 or 1/2 tubing with my set if rolls.
Sat Dec 14, 2013 5:26 pm
Post Re: Stringers
Sat Dec 14, 2013 6:30 pm
Post Re: Stringers
i bought a cheap roll bender from HF a while back for another project, will that work? Are yall using a die made for rec tubing or just pipe dies? Thanks
Sun Dec 15, 2013 6:11 pm
Post Re: Stringers
Sun Dec 15, 2013 6:22 pm
Post Re: Stringers
Swagoffroad.com
Sun Dec 15, 2013 7:11 pm
Post Re: Stringers
thanks. I will be starting my first boat build soon and have been hung up on bending the stringers. I am loving this site though, tons of info here!!!!
Sun Dec 15, 2013 7:29 pm
Post Re: Stringers
Mon Dec 16, 2013 1:08 pm
Users browsing this forum: No registered users and 61 guests
