It is currently Sun Jul 20, 2025 2:15 pm
Reply to topic  [ 7 posts ]
 Wiring thin wire
Post Wiring thin wire
So I got some cheapy led strips for my buddies boat. We tried to wire them up but the wire on these strips are super thin..
A) what gauge should I be using to connect to the strip
B) how do I connect the two? Without electrical tape!
Fri Dec 27, 2013 10:54 pm
Post Re: Wiring thin wire
Not sure if its the best way but...I stripped about 3/4" of the thin wire. Then I folded it 3 times so it would fit in a butt connector and I could make a good crimp.
BTW I used 14g .
Fri Dec 27, 2013 11:03 pm
Either a reducing connector or a terminal block. You could also solder them together and cover the splice with marine shrink wrap.
Fri Dec 27, 2013 11:22 pm
Look at scotch locks that's what I call them wired my old duck boat with them works from 19 gauge to 24 it's a telecommunications way of connecting telephone lines ... I do believe Home Depot will have them or your local hardware store they are filled with jelly so you won't have to worry about corrosion either hope that helps
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Fri Dec 27, 2013 11:24 pm
Fri Dec 27, 2013 11:26 pm
x2 on solder
i went from pbc connectors to solder b/c the pbc wasn't always getting a good connection.
GatorHide - MB
Fri Dec 27, 2013 11:31 pm
23 swomp/ 1542 tracker
Sat Dec 28, 2013 1:37 pm
Users browsing this forum: No registered users and 132 guests
