It is currently Sun Jul 20, 2025 1:52 am
Reply to topic  [ 13 posts ]
 What's yals opinion/thoughts on this set up?
Post What's yals opinion/thoughts on this set up?
Fixin to start building a boat with a stage 2 GTR. I haven't build any boats for a GTR yet so I wanna make sure the boat Im gonna build will perform right with it. Here's the specs: 17' with a 46" bottom, triple taper chine or double taper(depending on performance) 46" in between tapers, 6'-6'6" rake. 20" sides, hunt deck, 20.5" transom @ 20*. All 1/8" materials. With a hybrid V bow. I hunt timber 90% of the time so I can't have a very wide boat. What's yals thoughts on this set up?
1748 Boomer Custom in progress
Sat Jan 04, 2014 4:39 pm
Post Re: What's yals opinion/thoughts on this set up?
Sound like a good setup!!
Sent from my beeper
Sat Jan 04, 2014 4:46 pm
What's your thoughts on double vs triple taper chine?
Sat Jan 04, 2014 4:52 pm
Sat Jan 04, 2014 4:54 pm
Can someone explain the difference in handling and turning between double and triple taper chine?
Sent from my beeper
Sun Jan 05, 2014 5:39 am
Sun Jan 05, 2014 10:08 am
Boomer sounds like a good build to me. on your double or triple taper PM RJ (duckhunterF250) he has owned or built every chine from square to round. he can help you out and hes a good guy with lots of experience. good luck on your build keep us posted
Sun Jan 05, 2014 10:18 am
I would spend the extra $$ and use 5086 alloy and a 3/16" bottom. Rest of the boat will do fine with 1/8". I also placed 7 stringers instead of 5. Very, very solid boat. With your size boat the added weeight of using 3/16" on the hull would only add about 60 lbs. You would not hardly notice any difference in performance either.
1752 Uncle J, Calen Stage 1 35 GTR
Mon Jan 06, 2014 9:21 am
I will most definitely use 5086. And I built my last boat with a 3/16 bottom. Ill most likely end up doing the same on this one.
Mon Jan 06, 2014 10:38 am
Mon Jan 06, 2014 3:10 pm
True dat..
Mon Jan 06, 2014 7:10 pm
It's taken me 2 boats to figure out that I need 3/16! I would rather sacrifice speed for longevity!
Sent from my beeper
Mon Jan 06, 2014 7:15 pm
Def makes the last longer. Used 3/16 on my last one and I hit every stump I could find WOT and never did our a dent in the bottom
Tue Jan 07, 2014 11:14 am
Users browsing this forum: Google [Bot] and 74 guests
