It is currently Sun Jul 13, 2025 2:48 am
Reply to topic  [ 25 posts ]
 adding a hunt deck
Post adding a hunt deck
Ive seen a couple post a while back about adding a hunt deck from what I remembered about yall comments was it was a bad ideal
Has anyone done it and whats the negative about it? ?
Mon Feb 03, 2014 7:47 pm
Post Re: adding a hunt deck
I don't see why it would be a bad deal... As long as it's cut into the hull... Welding it to the hull they may have had some problems
Mon Feb 03, 2014 8:09 pm
hunt deck yes pods NO
Mon Feb 03, 2014 8:12 pm
sorry that might look wrong for what u are asking but do not put pods but yes u can add a hunt deck!
Mon Feb 03, 2014 8:14 pm
Autogateman did it I think.
Mon Feb 03, 2014 8:32 pm
Ive had it done twice, one being the boat I have now. Added on, not cut in. Works beautifully, just make sure a boat builder does it, not just someone who knows how to weld aluminum.
Mon Feb 03, 2014 8:40 pm
Well im not a boat builder but I did build this boat 2 yrs ago! !
Did you tie yours into the bsck of your old transom on the top and bottom of the new hunt deck?
Mon Feb 03, 2014 9:04 pm
I have a thread on this...added one to my boat few months back.ImageUploadedByTapatalk1391524852.909757.jpg
make sure to sure to use plenty bracing, double weld inside and out. I tied in the original runners through to the new transom also....Its alot of mess and checking angles and squareness. It was worth it to me though.
Sent from an Apple Tree..
Tue Feb 04, 2014 8:44 am
Does it make a difference if you foam fill it or just leave it hollow? ?
Tue Feb 04, 2014 8:51 am
About 10 lbs
Tue Feb 04, 2014 8:54 am
Tue Feb 04, 2014 8:55 am
Thats not the answers I was looking for but they were funny
Also if you add 2ft of huntdeck does that make it difficult to drive or do you buy a longer motor handle
Tue Feb 04, 2014 9:03 am
What differences do u think it will make if its foam filled?
Tue Feb 04, 2014 9:52 am
Well I typically cruise around looking for fat chicks ifits foam filled I can haul a couple more of them back home
Tue Feb 04, 2014 10:15 am
Foam doesnt help with bouyancy........
Every day I'm paddlin'
Tue Feb 04, 2014 10:20 am
Foam only comes to play when you try and do it backwards and put the water inside out instead of on the outside where it belongs....2' of huntdeck will increase buoyancy by quite a bit...mine is 16" and gave more maneuverability inside the boat without the tiller hangin way inside the boat
Tue Feb 04, 2014 10:44 am
16" gotcha!!
Any reason why you didnt taper the sides in jldsc?
Tue Feb 04, 2014 10:48 am
if you taper the bottom back of huntdeck and dont get the angle just right, it will cause the back end to suck down.... If i were to build another boat, it would be square at the transom....the angle does not help all that much in reverse except maybe with a prodrive since it is lifting the boat in reverse instead of pulling the boat down and the same in forward........
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Tue Feb 04, 2014 11:01 am
Right now im having trouble getting 3 guys 200,200,260lbs with all the hunting crap up on step it will do about 23 with this load
And add 1 more guy and it wont get up
Will the huntdeck help or hurt if I add it? ?
Currently its a 1648 w 35gtr stock
Oh empty boat with just me 200lbs it gps31
Tue Feb 04, 2014 11:36 am
mod the motor....... you will see better results...adding length will help the boat run "flatter" but it sounds like you need more rpms.......get a cam and then maybe exhaust and heads.....
Tue Feb 04, 2014 11:39 am
I just kept all the lines the same as the existing sides n bottom with a straight edge....just like it would have been on the boat originally.
Tue Feb 04, 2014 11:42 am
I was thinking about getting a hunt deck cut out of my 1754 gator tail just wondering if somebody had the dimensions of a factory gator tail hunt deck thanks
Sun Feb 09, 2014 8:18 pm
I have a 17x46 alweld, it squats very low with a 40outboard, I'm close to sealing a deal on a pd, but scared it will be somewhat sketchy as far as that much weight.. I wouldn't mind adding a huntdeck if I knew someone who could do it right, any help here?
Thu Apr 17, 2014 11:37 pm
Fri Apr 18, 2014 6:52 am
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Fri Apr 18, 2014 6:58 am
Users browsing this forum: Google [Bot] and 101 guests
