RyanOvertime
 Need some input *warning mudbuddy question inside*
So I have a war eagle 1848 and just put on a 35hp mudbuddy. My question is, is it unusual to have to shim the motor up from the transom? I only put it in water once to see how it was positioned and ran before drilling the transom to mount it. I was getting a lot of splash back over the transom. I'm new to mud motors and am not sure where I had it trimmed to exactly but I did get in contact with mudbuddy and they confirmed I have a short transom hull and motor.
Should I wait to bolt it down? Maybe I just had it trimmed to low for the speed? Please give me some input. Thanks.
Sun Jun 22, 2014 5:37 pm |
odass
 Re: Need some input *warning mudbuddy question inside*
Couple pics would help more than anything
_________________ Dead Fowl Custom 1954hd with a GTR
Sun Jun 22, 2014 5:53 pm |
RyanOvertime
im trying to post pictures but for some reason it wont upload.
Sun Jun 22, 2014 6:06 pm |
odass
Looks a little low (belt housing) might have to shim up a little bit. Did you ever get it to plane out?
Sun Jun 22, 2014 6:53 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
Yes it's too low
Sun Jun 22, 2014 7:09 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
Sun Jun 22, 2014 7:13 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
I'd go an inch at a time till it stops spraying you, your trim should be able to compensate for some of the issue you have going on there
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sun Jun 22, 2014 7:26 pm |
RyanOvertime
if the motor is trimmed wrong it will slash back correct? but if you can trim it to where it doesn't then its good?
Sun Jun 22, 2014 8:10 pm |
Bigrich
With you have a low transom I would be real careful not to sink it if u slow down to quick. I would try and build the transom up! On my last war eagle drop transom with just a 3 cylinder suk on the back I would take on water easy when slowed down and it didn't way nothing like a sd
Sun Jun 22, 2014 8:18 pm |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Mon Jun 23, 2014 5:32 am |
