Kdew05
 2 questions about hydroturf and short transom
Which hydroturf, pattern, color, ect. to use in boat? Can anyone tell me a pro about having a short transom?... All I can find is reasons not to have one, are there any reasons to have one or a time that it is better than a tall transom?.. (found a deal on a short transom boat)
_________________ 1854 GatorTrax GE chased by MB 5500 Mag
Thu Jun 26, 2014 10:18 am |
TonyGMcElroy
Joined: Tue Nov 15, 2011 3:27 pm Posts: 664 Location: Henderson, Tx
 Re: 2 questions about hydroturf and short transom
Any color or pattern and i like short transom when trying to go under low trees or pipelines
Thu Jun 26, 2014 10:23 am |
BKScripto
Color and pattern are subjective, pick out what you want. That being said, I'll probably use Swamp Camo in the groove cut when I put my order in.
I have to go under bridges a lot on the lakes I hunt, and when the water is up it can be a tight squeeze. The mud motors are already taller than a regular outboard, so I went with short shaft to give me a few extra inches of clearance.
Thu Jun 26, 2014 10:31 am |
basinhunter2012
i went short transom because theres bridges around me i have to get under also i go in the swamp a good bit here and dont hit as many low hanging limbs
Thu Jun 26, 2014 10:37 am |
OwenDickeson
I think the molded diamond turf is the most durable.
Thu Jun 26, 2014 10:57 am |
Frog
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Thu Jun 26, 2014 1:50 pm |
OwenDickeson
Thu Jun 26, 2014 2:03 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Thu Jun 26, 2014 2:39 pm |
OwenDickeson
The molded will hold up better. The only molded sheet is the diamond. Sucks its only available in the smaller sheets though.
Thu Jun 26, 2014 2:51 pm |
Frog
Thu Jun 26, 2014 3:34 pm |
Kdew05
Thanks for all the input, OD if you could shoot me your info so I can figure out how many sheets of which pattern would best suit what I'm looking for if you don't mind...
Thu Jun 26, 2014 7:45 pm |
nellie
Short transom for me as well, lower profile, easier to hide, easier to navigate around and under trees and low limbs when lakes and rivers rise. Some of these motors like Gatortail really stick up like a sore thumb on a tall transom.
Fri Jun 27, 2014 12:47 pm |
