dom
Joined: Fri Jan 31, 2014 1:01 pm Posts: 229 Location: Georgia
 Minn Kota battery charger issue
I bought a MK210D charger on my boat. Just plugged it in after going to the lake yesterday afternoon and it's showing that my starting battery (plug 2) is charging but it's showing a connection error with trolling battery (plug 1).
I've checked and double checked but the connection is good. Any ideas on fixing?
Has anyone had this issue with a charger before?
_________________ 1748 Prodigy with MB 4500 Black Death
Sun Jul 13, 2014 4:06 pm |
DuckHunterF250
Joined: Tue Jun 29, 2010 8:32 pm Posts: 1801 Location: atlanta texas
 Re: Minn Kota battery charger issue
Did u splice any of the leads coming out of the charger? Fuse good?
_________________ 1854 DeadFowl custom boat 35 GTR "The bitterness of poor quality remains long after the sweetness of low price is forgotten."
Sun Jul 13, 2014 4:13 pm |
missile
Joined: Mon Jun 18, 2012 7:33 pm Posts: 681 Location: DeKalb, Texas between the rivers
Also I have killed my battery completely and my charger would show this. I had to charge it with another charger then it kicked in and started to charge from my on board mk210D
_________________ Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's Boat Name: The Gar Barge Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sun Jul 13, 2014 4:19 pm |
Team Schmo
Joined: Sun Sep 08, 2013 8:05 pm Posts: 814 Location: Montana
How old is your trolling battery? Check fuse like stated above..
_________________ You can't fix stupid
Sun Jul 13, 2014 4:23 pm |
dom
Now the question is how to check the fuse. Do I just pull the wire or does it twist off?
Please forgive my newbness
Battery is brand new and the wire hasn't been cut at all so I'm thinking fuse issue
Sun Jul 13, 2014 6:21 pm |
missile
Twist and pull the fuse holder apart.
Sun Jul 13, 2014 7:31 pm |
Team Schmo
If it is not the fuse.. Take your one that is not working and put it on the battery that is just to see if you can make it light up if it will, then it's your battery.. Only reason I say this I had the problem last year with a battery that was only 6 months old.. If the batteries are junk the charging system will not work..
Sun Jul 13, 2014 9:51 pm |
dom
just to be sure... the fuse holder is attached to the main chargin unit behind the cable that goes to the battery.
Wanna make sure i'm pulling on the right thing.
Mon Jul 14, 2014 6:25 am |
Team Schmo
Yes and if your fuse is good try what I said above..
Mon Jul 14, 2014 6:26 am |
Dr.D
I mounted a mk battery charger too, had to use cutting boards to mount it to then the boards to the boat, charger itself shouldn't be touching the aluminum.
Sent from my LG-P870 using Tapatalk
_________________ Using Tapatalk
Mon Jul 14, 2014 7:05 am |
dom
update: after comparing front and back i learned i'm an idiot (shouldnt admit this on MMT) but i found the fuses and need new ones. should be charging this afternoon after i get some new 30 amp fuses.
Mon Jul 14, 2014 7:36 am |
