It is currently Tue Jul 08, 2025 10:25 am
Reply to topic  [ 5 posts ]
 spoolmate 100
Post spoolmate 100
i have a millermatic 200. i have figured out how to attach a spoolmate 100 to it w/o all the expensive parts. the mm200 is and older unit but it checks out good and all that ive read is its a good welder. question is has anyone used a spoolmate 100 to build a boat or do any extensive welding? ive heard they will melt down if put into any type of production work. i just want to play with alumnum and maybe some day attempt a boat. maybe fix mine if i rip a hole in it.
also if anyone is interested i have a millermatic 300 3 phase machine that i need to sell. great unit but i found out it was 3 phase after i got it. had it checked out and all is good. 2003 model
Thu Mar 20, 2014 3:34 pm
Post Re: spoolmate 100
Built mine with a 211 and the spoolmate 100. Runnin 5356 wire. Havent had serious problems yet.
35 GTR chasin a BBC 1848
Thu Mar 20, 2014 3:36 pm
Building mine with a mm212 and a spoolmate 100. Upgraded the gun with a (HD nozzle kit) basically a spoolmate 250.
Noticeable change. Better gas coverage, larger tips. part #'s are 195375, 196848 for the adapter and nozzle assembly. 199388 is for .035 tips. Only problems I've had so far has been the spool tensioner. It uses a rubber sleeve on the shaft and just doesnt seem to be consistent on my gun. I just loosen it up all the way and put a piece of cloth between the spool and spool cover and use the cover screw to apply pressure. The original tips for the spoolmate can be a pain to find locally when you're in a pinch. Hope this helps.
Thu Mar 20, 2014 4:28 pm
Thu Mar 20, 2014 4:38 pm
Newby here just joined in an attempt to get details from Hunt4Deer on how he hooked up his Spoolmate 100 to his Millermatic 200.
I am looking to do the exact same thing.
Any help would be greatly appreciated.
Thu Jul 17, 2014 12:55 pm
Users browsing this forum: No registered users and 99 guests
