It is currently Mon Jun 30, 2025 7:19 pm
Reply to topic  [ 12 posts ]
 1652 with 23 SD
New Member
Post 1652 with 23 SD
I'm sure it's been covered, but I'm considering a 1652 flat jon with a 23hp surface drive. Anyone else running something similar and what kind of speeds are you getting? The hull weighs around 350 lbs.
Thanks
Thu Aug 21, 2014 7:51 pm
Post Re: 1652 with 23 SD
I have a Monark 1542 with a custom deck in the front, bow fishing platform and a 23 hp mudbuddy. The bottom is not a truly a flat bottom (slight V) and does have longitudinal keel/ribs. Myself, my dog and minimal gear I can consistently run 21-22 mph. 2 guys, a dog and full hunt load and I am probably around 15 -16 mph. I bet you will top out about the same but probably wont lose as much when loaded.
1854 CC backyard build with GTR 37 EFI
Build thread here.. viewtopic.php?f=4&t=66815
Fri Aug 22, 2014 11:51 am
I'm running at 1544 slick bottom with a 23gdsd. I stay around 20-22 with a light load. Thinking about going to a Copperhead 23 to see a little more speed.
Fri Aug 22, 2014 2:07 pm
I have a 1548 Southfork hull with a 23 gtr. It's a semi-v open floor plan. With 2 people, I'm at 22mph in shallow water. Haven't tested speeds under a load, but with 4 people it struggles to get on plane. Your hull should carry a load much better though. Also, you will not regret the GTR! It is a badass little motor and reverse comes in handy a lot more than you might think.
1548 / 23 GTR
Fri Aug 22, 2014 2:11 pm
I have a 1650 xpress with a 23 hp long tail.. And It tops out empty around 19.. Go ahead and buy a 35 hp motor. Your boat should be big enough to hold it. Always get as much hp as you can afford and fit. I'm buying either a 35 MB or 35 Gtr in about 3 weeks.
Sat Aug 23, 2014 12:37 am
Running a 15-48 G-3 with a 23hp sd on it fine for 2 big boys around 20 -21mph. 22 by myself can't run 3 boys won't get on plane. Get a 35 so you don't have to later.
Sat Aug 23, 2014 5:47 am
You won't get max performance out of a job boat but it will do. A 23
Would push that 1652 Jon pretty good
40HP Gatortail
Sat Aug 23, 2014 5:51 am
I have a 1744 flat bottom with a 23. Hull weighs about 375 lbs. I get 23 mph with a 2 man hunting load and dog. 25 mph or so with a lighter fishing load. If you do it, get a light weight 23 Copperhead or similar.
Sent from my SCH-R950 using Tapatalk
Sat Aug 23, 2014 7:33 am
Guy here at work had a 1654 lowe with a 23gdsd and it was a dog
Ran 21mph with him solo
15 - 16mph with 2 guys
Not sure what shape prop was in i never looked at it
Sat Aug 23, 2014 8:56 am
I run a 1652 with a modded 35 on it. I wouldn't run that boat with less than a 35 or you will always be cussing at how it won't get on step with a load.
Sat Aug 23, 2014 11:29 am
I also have a 1651 with a modded 35. I'd never have anything less then what I have now. Too much boat and not enough power with those 23s. You won't like it loaded
Sat Aug 23, 2014 12:21 pm
I run a 1748 with my stage 2 23hp GTR. I get 26ish solo and 24 loaded with gear. My boat weighs in with tank batteries trolling motor etc at about 600lbs plus me solo.
Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here"
23GTR stage 2 by Calen pushin a 1746 Kliebert
Sat Aug 23, 2014 8:57 pm
Users browsing this forum: Google [Bot] and 165 guests
