It is currently Wed Jul 02, 2025 1:20 pm
Reply to topic  [ 11 posts ]
 Epoxy/resin boat bottom
Post Epoxy/resin boat bottom
I have a cheap 1436 I'm redoing now that season I over an not looking to put too much into. Can I use regular epoxy/resin to coat the bottom with to give it a little more durability and seal some pinholes? Will it be less friction than bare aluminum?
Thanks
Tue Jan 29, 2013 12:22 pm
Post Re: Epoxy/resin boat bottom
It will crack all to shit as the bottom flexes
Tue Jan 29, 2013 12:33 pm
Tue Jan 29, 2013 1:01 pm
Tue Jan 29, 2013 1:17 pm
Maybe I Gould ask this question: is there a cheap accessible (hardware store) product to coat the little part of tho hull that is in th water? I don't want to spend 100 dollars on a gallon that I will barely use any of.
Tue Jan 29, 2013 3:46 pm
They sell it by the quart.
Tue Jan 29, 2013 4:00 pm
Whoops scratch my previous post then^
Tue Jan 29, 2013 4:07 pm
Post Re: Epoxy/resin boat bottomom
werlons waterman,gatorglide are similar products are similar in performance and have good adheasion. If you go with a fill and primer to build up and fair the boot your looking at 300 bucks round about. Steelflex is thicker and cheeper but does not perform as good or last as long.
What are you trying to achieve? None of the products will help with speed in deep water or even mudd. It will help over vegition and stumps and unloading the boat. The water man is so slick I need someone to hook me up on a ramp because it will slide off before I can get to the front of the boat.
JD
Tue Jan 29, 2013 4:57 pm
JD
Tue Jan 29, 2013 4:58 pm
Go to Ipaint.com. Look for the industrial marine epoxy paint. Roll it on with a 3/8 inch nap roller.
1648 gd hull flying in front of a stage 3 with fpr
Wed Jan 30, 2013 6:47 am
New Member
Hi! I came accross a very interesting website with more info about epoxy-resin: http://www.nauticexpo.com/boat-manufact ... -1504.html . Hope this is a useful resource for you.
Mon Sep 29, 2014 3:06 am
Users browsing this forum: Majestic-12 [Bot] and 85 guests
