It is currently Wed Jul 02, 2025 7:23 am
Reply to topic  [ 15 posts ]
 Boat flotation or foam
Post Boat flotation or foam
I already performed a search.
But my question wasn't exactly answered.
I have a tracker grizzly 1648 ( garbage hull, I know)
If I cut the foam out of the boat. Is it more likely to sag in the water because the floatation is gone? Or will the removed weight allow the boat to draft higher in the water?
I want to cut the rear bench out of my tracker grizzly. The boat sits back ( weight In the rear) in the water a lot.
Don't wanna redistribute more people to the front or else the boat will plow.
Does the floatation actually help the boat float? Or does it keep the boat from sinking if u take on a shit load of water?
Thu Sep 25, 2014 7:12 am
Post Re: Boat flotation or foam
No it will actually float higher.
Thu Sep 25, 2014 7:13 am
Foam only helps once water is in the boat.
Thu Sep 25, 2014 7:14 am
Thu Sep 25, 2014 7:15 am
Exactly what I was thinking, thank you very much! Now cuttin all that crap out is gunna be a pain!
Next question if u don't mind.
How much would u guess all the foam weighs? Approximately
Thu Sep 25, 2014 7:24 am
Put in a garbage can and weigh it. If it's dry it won't be that much. If it's wet it may weigh a ton.
Thu Sep 25, 2014 7:27 am
Be carefully cutting seat out of a tin can boat. The way they are designed the seat tie yhe boat together and give rigidity.
Thu Sep 25, 2014 4:23 pm
Yea I was thinking that. I'm going to cut a rectangular hole, remove the foam, not the bench completely and use it as storage
Thu Sep 25, 2014 7:25 pm
My middle bench had a live well in the middle I cut it out capped the ends and used some angle iron the secure each side to the floor
Thu Sep 25, 2014 10:07 pm
What method did u use to extract the foam?
Thu Sep 25, 2014 10:45 pm
I pulled mine out useing a big flat bar.Beat it down in and break it up in chunks. It sucked but i got it done
Fri Sep 26, 2014 4:49 am
I know I am among foam haters here, but I encourage you to leave the foam in your boat if it is not water logged. To answer the last question in your original post: Yes, the foam is supposed to keep the boat from sinking if you take on a "shit load of water"
MoMarsh Fatboy/2 Honda
Fri Sep 26, 2014 9:06 am
This may help.
viewtopic.php?f=4&t=55950
MB 35hp LT/1754 Grizzly
Mon Sep 29, 2014 7:10 pm
I cut a hole in the top of both of the seats in my smaller riveted boat, took a large wood hole bit and a shop vac and went to town on the foam until i could pull out larger chunks... Once the foam was all out I added a a hatch to each seat and use the seats as storage... I pulled 150lbs of foam out...
1436 Lowe
Tue Sep 30, 2014 9:42 am
Damnnn that's a small person! If and when I do it, my boat should sit better. Thanks for the idea of the wood bit and shop vac.
Tue Sep 30, 2014 10:48 am
Users browsing this forum: No registered users and 124 guests
