It is currently Mon Jun 30, 2025 2:25 am
Reply to topic  [ 17 posts ]
 Grab bar console
Post Grab bar console
I'm looking at adding a small side console for grab bar, switches and cup holder. I've seen a few on here, but curious as to other options. Ordered my switches for to make a switch panel, all are carling waterproof rocker switches with custom faces to distinguish them. Want to make the grab bar removable. 4 bolts and it comes off or possibly a quick pin to remove it. Also will add a cup holder. On the cup holder, do you guys have holes in the bottom to let the water drain, and if so, do you have switches in it like I want to add. Curious as to the electrical with the water and corrosion. Here is a drawing of what I'm possibly looking at.
Tue Nov 04, 2014 6:22 am
Post Re: Grab bar console
We use the cup holder for access and put a drain hose on the bottom. Our new grab bar we went to a bolt instead of a pin with three different positions.
Corey Crochet
Cottonmouth Custom Boats, LLC
225-456-0930
Tue Nov 04, 2014 6:39 am
man, why does that boat look so familiar corey? lol
Tue Nov 04, 2014 1:27 pm
Yeah I thought about putting a drain on the bottom so the cup holder won't fill up with rain water.
Tue Nov 04, 2014 2:57 pm
Tue Nov 04, 2014 7:39 pm
Make it different. They all look the same. Make it have radius corners or something. If I ever build one I'm going to try to think of something to do a little different.
Sent from my beeper
Tue Nov 04, 2014 8:24 pm
Wed Nov 05, 2014 6:55 am
My grab bar console is built the same way and will be set up pretty close except my switch panel will be closest to me and has a 12v socket on the panel itself and the cup holder is a plastic insert
35 GTR on an 1844 Sportsman Fab hull
Build thread: viewtopic.php?f=6&t=57498
Wed Nov 05, 2014 9:02 am
Wed Nov 05, 2014 1:35 pm
I want to build one that I can put a GPS in the inside of it keep from limbs and stuff trying to rip it off.
Back Yard Bullshit 1848 with Delta stage II cam & heads, MAC, with a Mikuni juice pump.
No I wasn't talking about you but if the shoe fits lace that bitch up & wear it!!!!
Wed Nov 05, 2014 1:58 pm
Wed Nov 05, 2014 2:20 pm
Decided to just keep it simple. Switches won't be here till sat, so figured I'd get started.
Wed Nov 05, 2014 7:13 pm
Lookin' good man!
PRODRIVE 1860 CC
"Let the good times roll"
Wed Nov 05, 2014 9:53 pm
Wed Nov 05, 2014 9:57 pm
Thu Nov 06, 2014 5:53 am
Yes but I will mount it coming off the side instead of off the top.
Actually off the front vertical part.
Thu Nov 06, 2014 6:43 am
Thu Nov 06, 2014 7:09 am
Users browsing this forum: No registered users and 112 guests
